Old 08-02-2004, 01:28 PM   #1
hotrodtroy
hotrodtroy's Avatar
Can I get tid of this from mine
CPNE Thanks for the pic.
What is this tube for and is it needed?
'72 C-10 w/
'68 Large Journal 327cu.in.
"It's o.k. to dream about what you want to do, until you start doing what you are meant to do." Line from "The Rookie"
hotrodtroy is offline   Reply With Quote
Old 08-02-2004, 01:33 PM   #2
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
It looks to be just a hose coming out of an EGR hole. Since it appears the EGR is hooked up (driver's side front valve cover to carb base), I'd yank the hose and put a breather in there.
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 08-02-2004, 01:56 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
that, my friend, is a breather hose for the PCV system. filtered air from the air cleaner goes into that tube. just take it out & get a push-in breather (chromie) from your favorite parts store.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 08-02-2004, 02:22 PM   #4
shuttermutt
Yep, I didn't really pay attention to the hose, but 68C15 is absolutely right.
'Mutt
Old 08-02-2004, 02:25 PM   #5
cdowns
cdowns's Avatar
EGR=exhaust gas recirculation and it comes from the exhaust manifolds NOT THE VALVECOVER
Old 08-02-2004, 02:32 PM   #6
cdowns
cdowns's Avatar
another thing i notice is all that rubber hose that you're running to supply the carb with is just a great big old fire waiting to happen
Old 08-02-2004, 02:33 PM   #7
elk hunter
if you use the stock air cleaner spacer you will need to keep it. the engine sucks bypass pressure from the bottom end using this and the pcv. if you put a breather there instead, you will have to clean it often because of engine blow-by. i would use it.
yeah, but how's it wheel?
elk hunter is offline   Reply With Quote
Old 08-02-2004, 02:59 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Wow, those stupid GM engineers made that hose connect to the air cleaner when all they needed to do was install a slobbering chrome breather instead.
Old 08-02-2004, 03:38 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
That's what I was thinking. If you want the oil sludge all over your motor then a push in breather cap is for you. If you want that crap burntt off out the exhaust then plumb it to the base of your carb....
Old 08-02-2004, 04:46 PM   #10
demi
demi's Avatar
Most definately use it. It serves a very good purpose.
demi is offline   Reply With Quote
Old 08-02-2004, 04:55 PM   #11
hotrodtroy
hotrodtroy's Avatar
So it needs to go like this. I can't find any place for it to hook up to.does anyone have a better pic of it connected to the carb base.
Thanks,
Troy
'72 C-10 w/
Old 08-02-2004, 05:05 PM   #12
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
Forget the carb base...the hose hooks to the AIR CLEANER base, not the carb base. Don't have a pic handy, but there's a small plastic filter that fits on the inside of the air cleaner, with a round end that sticks through the air cleaner base. That hose plugs onto the filter end.
If you're going with an aftermarket air filter, check them first. Many have at least an attachment point for this hose.
Don't hook it to manifold vacuum (carb base). That'll cause all kinds of problems.
SSOW
69 C10 (#1 son's ride)
72 C20 (Dad's farm truck)
82 K30 (Ex - brush pumper project)
stickshift_or_walk is offline   Reply With Quote
Old 08-02-2004, 05:19 PM   #13
demi
demi's Avatar
The stock spacer for a small block will be taller than the BB one. Here's a quick pic of mine.
Old 08-02-2004, 05:27 PM   #14
hotrodtroy
hotrodtroy's Avatar
I don't have a spacer for my air cleaner (it's a 10" from Auto Zone), it just sits on top of the carb, and has no place for this hose to hook up to.
'72 C-10 w/
Old 08-02-2004, 05:32 PM   #15
crazy longhorn
Fabricate till you "puke"
I run a push in breather in my moroso covers, & dont have any problems with the eng puking oil out the top. my 383 is pretty fresh, but gets revved pretty tight at times. as low as the truck is geared, its pretty hard to shift fast enough to keep the eng under 6800-7000 for the 1st couple gears! I dont have to wipe oil sludge off the top of the eng crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-02-2004, 09:25 PM   #16
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
same here, i have 5000 miles on my new motor with a breather and no oil on my motor. doesnt quite get up to 6800-7000 but 5500 multiple times daily. with how long it takes to get oil to go down those aftermarket valve coler bafles i cant see any oil coming out very easily. unless something is cloged and the heads just fill up with oil, but then you have more that oil bolwage to worry about
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 08-03-2004, 05:26 PM   #17
Blue68
Blue68's Avatar
since you have an aftermarket breather, you are left with the push in chrome filter.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 08-03-2004, 07:53 PM   #18
shuttermutt
Which, consequently, isn't the end of the world that some folks would apparently have you believe. Yeah, they'll throw an oily mist on your valve covers. Yep, you'll need to wipe that off from time-to-time. Hey, if it bothers you that bad, either put on a stock air cleaner or get a crankcase evacuation system.
'Mutt
