08-02-2004, 04:41 PM | #1 |
Best way to cut dash to install CD player???
I've made up my mind and just decided to cut the dash and install a CD player. I have the sleeve thing for the CD player to use as a template but I was wondering what tool is the best for cutting the dash. I would like to cut just inside of what I need then used a file to fit it just right. Thanks.
1972 K-10 Longbox,6" lift w/35's/350/SM465/NP205/3.73 1972 C-10 Longbox,350/350 1998 Pontiac Grand Prix GTP FOR SALE: 1971 K-10 Longbox,350/SM465/NP205 |
08-02-2004, 05:06 PM | #2 |
Be vewy, vewy cawlful.
Sounds like you have a good plan. A coping saw worked good on mine. Good luck
'72 C-10 w/ '68 Large Journal 327cu.in. "It's o.k. to dream about what you want to do, until you start doing what you are meant to do." Line from "The Rookie" |
08-02-2004, 06:06 PM | #3 |
Do you have a drimel or angle grinder/ cut off wheel? Tape off where the cut is to be made and go slow
08-02-2004, 06:13 PM | #4 |
Member since 2000
use either a air saw or dremel. the die-grinder is to big and doesn't work well for this situation. But if all you have is a die grinder, tape it off, and don't over cut cause you can always file it down.
08-02-2004, 06:27 PM | #5 |
option other than cutting
I read somewhere in a magazine about a guy who takes stock radios for classic vehicles, takes the guts out ,and converts them into cd players. It sounded pretty cool to me especially if you have a nice vehicle that you don't want to mess up. Just a thought
08-02-2004, 07:21 PM | #6 |
Got Light Emitting Diode?
i used a sawzall and went real slow with a fine tooth blade. and filed it to fit. good luck and dont mess up
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
08-02-2004, 08:37 PM | #7 |
Keep On Truckin'
I'm trying to remember when I did mine and as I recall the DIN size hole wasn't large enough to cover up the factory holes. I cut the hole out in the factory location to the edge of the indentation and welded in a solid plate of 16 gauge and then cut the DIN size hole in the plate. I used a jig saw with a very fine tooth blade.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
08-02-2004, 09:47 PM | #8 |
Member since 2000
Do a search on "metra" they are leading producer of kits, harnesses, and what not to adapt a aftermarket radio to any car. THey also sell a wide variety of trim rings to fill any gaps around the radio.
Plenty of members have installed aftermarket radios without any problem. Most trim rings cover any little gaps around the radio. You could always get a center console, drop in a pioneer head unit in it and put a 7 inch wide /touch screen where the O.E. radio go's Metra Link Last edited by Alexis; 08-02-2004 at 09:52 PM. |
08-02-2004, 09:58 PM | #9 |
graphic designer
i used a body saw (really small sawsall - my dad owns a body shop! Lots of cool tools!) my kenwood surround wouldn't cover the factory indents for the knobs, so i cut a piece of aluminum sheet a little oversized, enough to cover the indents, and stuck it in place with 3M body moulding tape. kinda a brushed look, really subtle. kinda looks factory/custom, if that makes any sense! i can post a pic in a day or so if you are interested. as for cutting the hole, might try a jig saw, but tape everything to avoid scratches. and watch what is behind!
08-02-2004, 09:59 PM | #10 |
Member since 2000
wierd
there catalog has a bunch of item for this situation but there online product list doesn't list any. |
08-02-2004, 10:20 PM | #11 |
its all about the +6 inches
In case you don't have any of these neat tools, and you might want a low buck way to do it, I used a hack saw blade and held it with some Vies-Grips. Did an awsome job, just took a little longer, and there was lass chance of screwing up.
08-02-2004, 10:21 PM | #12 |
Seņor Member
Let me know if you need some help...
08-02-2004, 11:20 PM | #13 |
SLOW BUT SURE,BUT CLOSER
The thread of the the unpardonable sin!!!!!!!!! LOL!!!!!!
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... |
08-02-2004, 11:24 PM | #14 | |
08-03-2004, 12:23 AM | #15 |
i love summertime
ask cpne...he has done this to all his trucks
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
08-03-2004, 05:15 AM | #16 |
I'm just looking for a set of doors good enough to install speakers in...they can always be welded back up later is some one doesn't like them.
08-03-2004, 12:31 PM | #17 |
68 C/10
I have my dash out now and plan to cut and weld in a new piece of steel, then cut out for the cd player. Hope it looks a little more factory.
(2009) GMC Sierra Denali 6.2 AWD (67 C/10 fleetside SWB) (2018GMC Yukon Denali) Wifes Car |
08-03-2004, 12:48 PM | #18 | |
Resident Curmudgeon
Sorry, can't help.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
08-03-2004, 01:51 PM | #19 |
blood type; Retumbo
after 2 1/2 years of ownership I still dont have a radio. I do have a delete plate in my toolbox though.
you could do what I do on road trips... sing X-mas songs. makes the wife wonder if I am worth it & son thinks he is adopted. I do have a frenching panel for a CD player that I made if I ever get that far.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
08-03-2004, 02:23 PM | #20 |
Left Foot Functioning
Back to the original issue...
The topic was how to do it well, right?
Speaking of delete plates, has anyone used that plate as the basic mounting flange for the DIN chassis, and come up with a slick way to hold it all together? That would at least cover the shaft indentations. SSOW
69 C10 (#1 son's ride) 72 C20 (Dad's farm truck) 82 K30 (Ex - brush pumper project) |
08-03-2004, 02:54 PM | #21 | |
Resident Curmudgeon
08-03-2004, 04:50 PM | #22 |
thats a cool 'flip face'
08-03-2004, 08:59 PM | #23 | |
BlahBlahBlah
