Is a bullfrog waterproof?
4wd Question???
My wife backed out of the driveway Sat. afternoon and started down the street, pulled into the neighbor's driveway, turned around and came back home and said something there is problem with the Suburban. She said it felt like the right front tire was flat but it wasn't. I backed it out and started down the street and turned around in the same driveway and it felt like the steering was very, very stiff. I had cleaned the dash earlier and I noticed that the 4WD light on the dash was on. This is on a 97 GMC Suburban. Appartently I had hit the switch (it has the electronic transfer switches on the dash) when I was wiping the dash trying to get the dust out of the cracks and put it into 4 High. As long as you were going straight it was fine, but when you try to turn either direction going forward or backward it was like it had manual steering. This is the first time I have ever had it in 4WD since we've owned it. I put it back in 2WD and it's fine. Pavement was dry as a bone. Just wondering it this is normal???
"It is better to remain silent and be thought a fool, than to open one's mouth and remove all doubt." Ben Franklin __________________ 1970 Chevy shortbed 2002 Harley Custom Chopper (Long sucker) 1998 K2500 5.7L 5-speed Longbed 1st two are My son's toys...they just live in my garage! 1997 GMC K1500 Suburban 1993 S-10 Blazer 4D (youngest son's daily driver) 2000 Dodge Ram 4WD Ext. Cab (5.9L) Wife is a late year 1951 |
Yep, normal. Mine does the same thing. I try to run the 4wd at least once a month to keep everything moving. I do the same thing, drive it up and down the street, hard to steer on the pavement.
'98 Chevy Silverado Ex Cab Z-71 '02 GMC Yukon SLE 4x4 |
it is your front tires grabbing because in 4x4 there is power going to the front wheels as well as the back therefore they are grabbing some traction should feel kinda jerky
This is why they should have put a light in the dash next to the gages that lights up 4HI 4LOW etc. The little button lights are useless.
I did the same thing once and beat myself up over it, not good for drivetrain. What happens in a turn in 4wd is you tires are rotating at different speeds, inside tires are turning slower than outside tires. This is being accomplished trying to use the same axleshaft and driveshaft rotations. On dry pavement this hurts but on loose traction applications its fun
1998 Yukon SLT K&N FIPK Flowmaster Force II Catback Exh. Hypertech 160 T Stat / Pwr Program G80: Locking, Rear Axle GT4: 3.73:1 Rear Axle Ratio KNP: Transmission Oil Cooler NZZ: Skid Plate Off-Road Z82: Trailer Pack Last edited by 1998 YUKON SLT; 08-03-2004 at 05:25 PM. |
Don't use 4WD unless you are driving in snow and ice, or a dirt road. Your truck feels like it's binding because it is. Your tires need to turn at different speeds when you go around a corner, but when you are in 4wd, they turn at the same speed. Your differentials will all different wheel speeds side to side, but there is nothing to allow different speeds front to rear. On slippery pavement, the tires slip and everything is ok, but on dry pavement, you get binding.
#6 | |
95 K3500 SRW 5.7L Vortec 4L80e 4.10 G80 2001 GMC C3 6.0 AWD, Volant, 3/5 drop TBSS intake, HP tuners, pullies, 05 efans, 05 front brakes, etc. 2003 Tahoe Z71 Silverado front clip |
| Bookmarks |
