08-02-2004, 08:56 PM | #1 |
ran out of money
help with cig lighter!! wires?
I need to hook up my cig. lighter..... but i dont know were the wires go to... i have a painless harness in the truck so i have a wire going from that to the cig. lighter but my cig. lighter aslo has 2 wires coming out of it..... could someone please tell me if the other is just simply a ground or what it is....
Thanks a lot Rat
Modify everything, leave nothing alone!~ |
08-02-2004, 08:59 PM | #2 |
Cause the Chicks DIG IT!!
I believe that 2nd terminal will be for a ground. If you are putting the cig lighter in the original dash location though you shouldn't have to worry about it because it is self grounding. Or at least should be. If that don't work will then Hook up a simple ground.
08-02-2004, 09:00 PM | #3 |
Got Light Emitting Diode?
it must be a ground. mine just has one wire and it grounds to the dash when you screw it together
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
08-02-2004, 09:32 PM | #4 |
ran out of money
its in the stock location but it is some aftermarket/repo type deal.... looks like stock but my truck never had a cig lighter i only had a little black plug!!!
Thanks Rat
08-02-2004, 09:37 PM | #5 |
JB-80 "Twice as Good"
Did'nt some lighters have one wire for power and another wire for a light?(so you could see where to put it back)....then grounded to the dashboard.
Might be thinking Pontiac here......but you know GM!
HEY NOW! |
08-02-2004, 10:22 PM | #6 |
its all about the +6 inches
Yes, many of the Cigar Lighters had a light. If you still have the stock wires on the lighter socket, the red is the lighter power, and the green is the light, wire it to the 'lights' section in the fuse box, the stock box had that, and I'm sure your after market one does too...if it does not, you could get the light's power from the heater controll panel light.
