Old 08-02-2004, 09:31 PM   #1
kickinasphalt
kickinasphalt's Avatar
What is the correct way for the gas pedal to be connected to the rod???
My pedal fell of on my 72 K10 a while back and all that was holding it on was a little bolt that wasn't long enough to get enough threads on the nut. Is this what they used from the factory?
1972 K-10 Longbox,6" lift w/35's/350/SM465/NP205/3.73
1972 C-10 Longbox,350/350
1998 Pontiac Grand Prix GTP
FOR SALE: 1971 K-10 Longbox,350/SM465/NP205
kickinasphalt is offline   Reply With Quote
Old 08-02-2004, 10:02 PM   #2
724wdcopper
graphic designer
724wdcopper's Avatar
if i remember correctly, a pin with a cotter pin is what is holding mine. i put the cheyenne trim on my pedals a few years ago, and this is what i remember being there. a bolt and nut would work if it is not so tight as to limit the movement of the pedal. and dont forget the spring, or you'll have hanging pedal syndrome, and no one wants that!
724wdcopper is offline   Reply With Quote
Old 08-02-2004, 10:33 PM   #3
kickinasphalt
Cotter pin makes more sense. Where is this spring you speak of? I didn't see any in that area. I actually think I need to have the pedal off the floor more as I don't think I'm getting WOT when its down all the way. You can lift the pedal off the floor about another inch. I think its needs to be lifted, the the end of the throttle cable moved more forward to keep the pedal that way.
Old 08-02-2004, 10:40 PM   #4
724wdcopper
graphic designer
there is a spring that the pin holds on and creates tension to keep the pedal from drooping straight up and down. it is a pretty light spring. you might check under the seat or floormats for it. a buddy of mine had the same problem you are talking about, not full throttle. he bent the steel rod up so it was more of an L shape. it worked for him, but check it out first. i think he had a He11 of a time bending the rod. i guess it is pretty hard.
lots of luck!
Old 08-02-2004, 11:22 PM   #5
blazer1971
The pin is made for a snug fit in the pedal and the spring is need to keep pedal off the floor and in correct position. Both the pin and spring need to be put in place at the same time. This can be a little tricky.
blazer1971 is offline   Reply With Quote
