Old 08-02-2004, 09:50 PM   #1
724wdcopper
graphic designer
724wdcopper's Avatar
different doors?
my drivers door has the adjustment screw just under the vent window to, i assume, keep the sill from spreading. the pass side has no screw (or indent for one) but does have the "tab" inside. it is spreading a little. to do a 1 piece side window conversion, what do i do with the screw in the drivers door? i have an article in some mag that has a crew doing the conversion on a sub, but it is the tab (no screw) sytle door. and this article shows the crew cutting out the tab. won't this allow the sill to spread?
do i have different year doors? is there a way to convert the screw door? has anyone run into this and found a solution?
thanks
724wdcopper is offline   Reply With Quote
Old 08-02-2004, 10:19 PM   #2
Harold Shepard
You have a 72 door (with screw) and a 71- earlier door (no screw). I think the idea with the screw was to help the tab from breaking under pressure from the vent windows. One piece will get rid of this problem.
Harold Shepard is offline   Reply With Quote
Old 08-02-2004, 10:27 PM   #3
724wdcopper
graphic designer
thanks! just what i wanted to hear! now, about that $350 window kit . . . .
