Old 08-03-2004, 03:34 AM   #1
jasonrog
jasonrog's Avatar
Power steering pump
I have a serpentine system from a 90 chevy on my 71. The PS pump is shot and needs to be replaced. Can I use any pump and just switch pulleys?
Jason
jasonrog is offline   Reply With Quote
Old 08-04-2004, 02:54 AM   #2
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Did your pressure hose from the pump to box fit ok? I have a 91 set-up and the pump is a metric threaded pressure hose. Box is standard thread. I have a custom made hose metric one side standard the other. Also pump is tapered, on a 72 c20, and straight on a 91. Serpentine pulleys won't fit early pumps....Of course I am no expert. Anyone else know fer sure?
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 08-04-2004, 07:04 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Jasonrog, just ask for the later model pump from your parts guy. Tell him it's a 90 model truck.
chickenwing- Screw that big 1 inch fitting out of the back of your metric pump and screw a normal flare type one in. Be careful that you don't leave the spring out.
Problem solved.
Old 08-04-2004, 11:00 AM   #4
jasonrog
jasonrog's Avatar
Thanks for the replys, However I am cheap and am going to my local wrecking yard on Friday. So a serpentine pulley WILL NOT fit on a older v belt pully pump?
Jason
Old 08-04-2004, 11:07 AM   #5
Tx Firefighter
I don't know If a v belt and serp belt pump will interchange. i always just buy the right pump. You can get one off of a truck, van, suburban, or even any 4.3 V6 vehicle. The 4.3 uses the same front setup as the V8 does
Old 08-04-2004, 12:01 PM   #6
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
Originally Posted by Tx Firefighter
chickenwing- Screw that big 1 inch fitting out of the back of your metric pump and screw a normal flare type one in. Be careful that you don't leave the spring out. Problem solved.
Great tip, Tx, I can use this one. Since I'm doing the PS conversion from scratch, can you show me the "flare type" fitting you're talking about? And what models to check for one? Bound to be cheaper than a custom hose...
Thanks...SSOW
69 C10 (#1 son's ride)
72 C20 (Dad's farm truck)
82 K30 (Ex - brush pumper project)
stickshift_or_walk is offline   Reply With Quote
Old 08-04-2004, 07:22 PM   #7
chickenwing
Thumbs up
Problem solved.
WOW! I never thought to try and change the fittings! I could have raped the one from my old pump I threw out! Well the hose is allready made. When it does go I will try your suggestion. Thanks!
Rich
Old 08-17-2004, 11:12 PM   #8
stickshift_or_walk
Ok, serpentine setup retrieved, and it's time to do the new hose setup. I'm getting a new PS gearbox (for the '69 application), so I'll need to make the new (89' model) pump talk to the old gearbox.
The arrow below in the pic shows what must be the fitting that Tx_Firefighter recommends to swap for a flare fitting that will fit the hose end for the '69. What I'd like to do is just buy new PS hoses for the '69 application, and replace that flare fitting. Does anyone know the specs for that flare fitting, and where I can get one?
Also, it appears the other hose (low pressure return) will just attach to the pump with a hose clamp, so no mods needed there. Is that correct?
Thanks...SSOW
Old 08-17-2004, 11:27 PM   #9
chickenwing
I understood from Tx Firefighter's post that you could re-use the fitting from the old pump. He said to make sure not to leave the spring out. Thought I would figure it out when the time comes. The 69 pressure hose might need a little massaging to fit between the pump and the block, it's tight in there. The low pressure line just clamps on.
Rich
Old 08-17-2004, 11:56 PM   #10
stickshift_or_walk
Ah, there would be the problem...I don't have an old pump. That gunked-up one in the pic is the only one I've got - it's the one that was on the '89 I grabbed the serpentine setup from...SSOW
Old 08-18-2004, 12:07 AM   #11
chickenwing
Oh. Go down to the junk-yard rape the fitting from a donor. Dunno if the 73 and up pumps would work but suspect they will.
Rich
Old 08-18-2004, 12:14 AM   #12
'71c204x4454
'71k204x4454
I had a power steering pump off a '98 dodge Dakota with a serpentine pulley sitting around and started looking at is and it bolted right in. No changing fittings or anything. I had to change to a v-belt pulley since I didn't have a serpentine system. But it's still working.
1971 K20 4x4
1964 buick skylark convertible
'71c204x4454 is offline   Reply With Quote
Old 08-18-2004, 04:23 AM   #13
Blue Beard
Blue Beard's Avatar
Did you put this setup on the truck....or previous owner?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 08-18-2004, 09:05 AM   #14
stickshift_or_walk
Blue Beard,
If your question is for me, we're doing the conversion. '69 C10 has manual steering, we're going with a I6-V8 swap, and wanted the serpentine pulley system. Since virtually all serpentine setups (even aftermarket) have provisions for the P/S pump, we decided to go ahead and convert the truck.
I pulled all other engine accessories from the '89 C1500 when I got the serpentine brackets.
SSOW
Old 08-19-2004, 01:35 AM   #15
chickenwing
Were the 89 1500 brackets aluminum or steel? I got mine of a 91 2500 and they were aluminum. If it cracks want the steel ones.
Old 08-19-2004, 09:33 AM   #16
stickshift_or_walk
They're steel - visible in the pic above, but filthy. Had to get the pulley off to even remove the pump from the bracket.
We had my Dad's cast brackets break clean off on a fishing trip once, a major inconvenience. So when I found the steel setup, I grabbed it. At least if it cracks, I can weld/brace it...
SSOW
