Old 08-03-2004, 06:44 PM   #1
Jeremy_5
Truck addict
Jeremy_5's Avatar
can you identify this wire for me
I will try to describe this the best I can, I know a picture would help and if I can get ahold of a digital camera I will go snap one. Anyways, on the heater control there is a yellow half round looking thing, there is two yellow wires running into it. What is this? I am trying to hook up my A.M. radio and the someone did a hack job on the wires, it looks like the wire that runs out of the fuse box labeled "radio" runs to that yellow thing and then is spliced and I think it ran to the old radio. Any help would be appreciated.
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Jeremy_5 is offline   Reply With Quote
Old 08-03-2004, 09:11 PM   #2
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
Is it an AC truck? and are you talking about the heater control switches? somebody might know what you're talking about but I need a little more info I guess.
WRMZ71 is offline   Reply With Quote
Old 08-03-2004, 09:40 PM   #3
Jeremy_5
Truck addict
Jeremy_5's Avatar
It's a non AC truck, and yes I am talking about the heater control switches but it can only be seen if you take out the control switches and let it hang down, it is not actually on the panel of control switches. I am sure this is not the best explanation so I will get ahold of a digital camera so I can take a picture of it.
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Old 08-03-2004, 10:34 PM   #4
68C15
blood type; Retumbo
68C15's Avatar
is it powerd with the dash lights? I will have to look at my wiring diagram. not sure if it is same as a '68.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 08-04-2004, 01:41 AM   #5
Jeremy_5
Truck addict
Jeremy_5's Avatar
Thanks 68C15, I would look at my wiring diagram but I cannot figure those stupid things out, it is like I am looking at a foreign language, I don't know how you guys read those things.
No it doesn't look to be powered by dash lights, got the camera pic will be posted tomorrow.
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Old 08-04-2004, 08:50 AM   #6
JimKshortstep4x4
Smile
It sounds like someone ran a wire from the radio terminal on the fuse panel to the heater control and then fed the radio off of a junction.
The factory radio wiring was a red wire and it fed the radio separately. The heater control was fed with a fairly large brown wire, (10 gage?).
The heater blower needs a large wire and I would suggest getting another harness or refeed the heater switch with a separate feed.
Jim
Old 09-02-2004, 03:20 AM   #7
Jeremy_5
Truck addict
Jeremy_5's Avatar
here is the picture...
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Old 09-02-2004, 04:46 AM   #8
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Dude that's some kind of transformer.
That is a PO addition.Definitly not a stock item.
Whats it connected to?
I also see what might be a resistor(blue tube thing).It might be a power supply to a 6V radio?Stepping down the voltage from 12V to 6V.
If you have a meter measure the output voltage.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 09-02-2004, 06:52 AM   #9
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I bet it's something added by PO to filter out alternator noise in the radio. The blue thing is a capacitor, that and the transformer(coil) would be a filter.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 09-02-2004, 07:32 AM   #10
Old Dave
Is a bullfrog waterproof?
Old Dave's Avatar
JIMS70GMC is correct it's a LC (inductor-capacitor) to help filter out alternator whine and probably whine from the blower motor. Remove it, and while you're at it take out out all those crimp wire nuts as they are a source of problems. Solder the wires back together and use heat shrink tubing on your connections and you won't have any problems.
"It is better to remain silent and be thought a fool, than to open one's mouth and remove all doubt."
Ben Franklin
1970 Chevy shortbed
2002 Harley Custom Chopper (Long sucker)
1998 K2500 5.7L 5-speed Longbed
1st two are My son's toys...they just live in my garage!
1997 GMC K1500 Suburban
1993 S-10 Blazer 4D (youngest son's daily driver)
2000 Dodge Ram 4WD Ext. Cab (5.9L)
Wife is a late year 1951
Old Dave is offline   Reply With Quote
Old 09-02-2004, 11:26 AM   #11
Davy
Davy's Avatar
Sweet VIKINGS key chain!
1970 Blazer CST
Looking for NOS items for my CST restoration.
Davy is offline   Reply With Quote
Old 09-02-2004, 03:27 PM   #12
Jeremy_5
Truck addict
Jeremy_5's Avatar
thanks for all the replies guys!!! So can I just remove the yellow thing altogether? It looked factory to me, shows what I know
Davy, Ya go VIKINGS!!! They are going to pretty good this year!
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Old 09-02-2004, 03:39 PM   #13
mhicks
mhicks's Avatar
If you remove it and your stereo start making a wining noise through the speakers then hook it back up. It is a noise filter.
mhicks is offline   Reply With Quote
Old 09-02-2004, 03:47 PM   #14
Jeremy_5
Truck addict
Jeremy_5's Avatar
gotcha, thanks
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
