<<< R 67 PROJECT
How low can I go???
We have a father and 2 sons 78 2wd blazer project and this is new to me how low can I go without notching and or putting different spindles? can you put blocks in back and cut front springs lower stance shocks? like I said I'm new at this and we are on a budget if we were not this puppy would be slammed but we are so any help and ideas would be gr8.
I need passenger side door and fender also a hood any good deals out there? we live in White Settlement Tx. / D/FW area......thanks guys/gals we just registered and I cant seem to leave this site my boys ( 12 and 10 ) just freak out when they see some of these rides.
NEW BABY!!! '67 STEPSIDE FRAME OFF PROJECT bullstowin40@sbcglobal.net -92 2wd burb 225k dailey driver -98 nissan quest the wifes -67 C-10 stepside my toy |
<<< R 67 PROJECT
new here be nice
just realized there's a suspension section so sorry,but if u can help thank you
Active Member
I've done drops on both my '79 resto and the blazer and have used Western Chassis both times. It's fairly economical depending on amount of drop. You can do a simple 3/4 drop for around $250 with dropped coils in front and shackels and hangers in the rear (won't need a notch with that).
go to www.sporttruckdirect.com and you can get a good idea of options.
D.M.C -FF- |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Mine is 5 1/2 inch drop in front, and 5 inch in the back.
Spindles and springs in the front cost about 300 Rear leaf spring dearch cost 90 dollars at Ft Worth Champion Spring shop on Henderson street in downtown Ft Worth.
<<< R 67 PROJECT
Thank you
Tx Firefighter did you take the springs off and take them to the shop or did you take the blazer to them?
By the way your wifes blazer is sharp and well worth the $10k
I measured how much I wanted to lower it then removed the springs and took them over to Champion.
My springs had sagged differently over the years and one actually set almost an inch lower than the other. When I took them to be de-arched, I just marked one with the 5 inches and the other one with the 4 1/16 inch or whatever. They de-arched them down to what I wanted and compensated between the two so that the truck sits properly side-to-side now. The price also included all new bushings installed too.
