Old 08-04-2004, 06:07 PM   #1
PrimeredThunder
Back from the Dead
PrimeredThunder's Avatar
Running exhaust OUTSIDE of the frame?
Is it possible to run the exhaust outside of the frame on a 67-72 Chevy truck? I would be running Ramshorn Manifolds and using Flowmaster mufflers. The mufflers would be mounted underneath the doors and have turndowns.
Yes, I know it will be loud, especialy in the cab, but I need to do it for ground clearance if I go through with lowering my truck even more this winter. Any pictures or suggestions would be great.
Thanks,
Kenny
The only Carb that matters to me is the one under my hood!
Salem, Oregon
PrimeredThunder is offline   Reply With Quote
Old 08-04-2004, 06:10 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Lots of guys have run them outside the frame. Usually, you can see where the bottom corner of the cab is bent for the pipes to run through. Usually, you can bend them back later if you want.
Old 08-04-2004, 06:32 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Talking
My Old 70 With The 250 In It Had A 3" Flow Under The Drivers Side
With A Turn Down, I Loved It, Until I Hit Something & Tore It Off.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-04-2004, 07:55 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Wouldn't the floor be higher on the inside of the frame rail than on the outside? (Where the floor slopes down to the door opening) Any good pipe shop should be able to run a set of pipes back to the bed and stay inside the frame rails. The only mod you'd have to do is chop a hole in the cross member for the pipe(s). I've seen quite a few with the X-member cut (the one where the C-bearing is if so equipped) and one of them was a 12 second street driven daily driver.
Old 08-04-2004, 08:11 PM   #5
XXL
Seņor Member
XXL's Avatar
I ran mine like this. The turnout from the engine happens just forward of the firewall where the frame curves up. Once it's outside the frame rail it's all done. Muffler behind the rocker panel and then between the cab rear and mount to get under the bed. As TX mentioned, you do have to notch/bend the inner edge of the rear of the cab to get a little clearance. Rinse. Repeat.
XXL is offline   Reply With Quote
Old 08-04-2004, 08:22 PM   #6
67cst
i love summertime
67cst's Avatar
mine are inside the frame rails and tucked waaaaay up, i think its a great setup, the pipes run though the crossmemeber described in the post above
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 08-04-2004, 09:23 PM   #7
68C15
blood type; Retumbo
68C15's Avatar
I see where he is coming from on this question. with the trailing arm style rears there is very little room for exhaust. factor in the lowered suspension & you are just about of options.
I am going with a big block which will need 3" pipes & headers. I plan on using the 4" round magnaflows & would also like them outside the frame for rear suspension clearance. can a guy go through the frame sides under the cab safely? maybe box that area for strength? then run them along frame with mufflers under the bed?
just brainstorming, thanks.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 08-05-2004, 03:23 AM   #8
PrimeredThunder
Back from the Dead
Thanks for the help and suggestions...
I considered running it back above the frame and thr0ough the Trailing-Arm Crossmember with holes, but I plan on doing some surgery on the back of my frame and I need all the room I can get.
If anyone has a setup like I mentioned PLEASE post pictures!
Kenny
Salem, Oregon
