Old 08-04-2004, 09:24 PM   #1
biglou55
Question need help ? engine numbers
I have a 69 3/4 ton 2 wd. i was told it was a 327 cid/325 hp. I have not pulled the engine yet so i cant read the casting # yet. the #s i do have are on the pass. side behind the alt. engine suffix code is v113ockd partial vin in the same place is 12k545158 i can,t find it at mortec. another site came up with a engine suffix code for a350 cid 1972/1977 years. the oil filler tube is in front of the engine in the center like the early 327 s any help with the suffix and vin #s would be very apreciated thank,s big lou55.
Certifiably crazy person
biglou55 is offline   Reply With Quote
Old 08-04-2004, 09:33 PM   #2
68 Suburban
68 Suburban's Avatar
at nastyz28.com, this is what it list:
1972 CKD 350 tur hydro trans 175 4 F A B X
1973 CKD 350 tur hydro, Calif L48 200 4 A B F X
1974 CKD 350 T350 NB2 - 4 A B F X
1977 CKD 350 a/t, high altitude L L48 180 4 Vette
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 08-04-2004, 09:59 PM   #3
biglou55
Exclamation
I got that off of that site also . I guess i will have to wait until i pull it for the casting # can anybody help with the vin # to find out what engine it is thank,s biglou55. the guy swears the engine was not changed since the truck was new . I didn,t think they made 350 s in 69.
Old 08-05-2004, 06:22 AM   #4
biglou55
Question
Can anybody help?
Old 08-05-2004, 06:43 AM   #5
GMC AMI
GMC AMI's Avatar
Wink
Originally Posted by biglou55
Can anybody help?
It may be possible that someone swapped the intake and put on the 350 to keep original look. The #'s are for the 350 and they do not lie. Most 327's are a y suffix code. If you clean the area where the block casting is, you can use a mirror to see the code even in the closest to firewall engine position. Good luck
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
