Old 08-05-2004, 01:59 AM   #1
alpha_male0203
95 extended cab sportside
alpha_male0203's Avatar
Question 350 people
what type of carb would you insist on useing for your 350?
i need a new carb and all i was going to go edelbrock but i am not sure b/c of the price
what do you need a manual for eletrice choke notr sure i dont know much about this but plain to learn
i was thinking the thunder se4rice for eldebrock you heard of it i am sure let know thanks
95 Chevy k 1500
00 Chevy Silverado 1500
07 cobalt Old ladies car]
alpha_male0203 is offline   Reply With Quote
Old 08-05-2004, 03:28 AM   #2
Tom
driving is in my blood
Tom's Avatar
If I had lots of money I would run a demon on every carb'd vehicle I own, but I don't. So the daily has a carter 600cfm and the toy has a holley 750DP. If I was about to spend money on a new carb I would buy a used demon off ebay instead
Old 08-05-2004, 03:43 AM   #3
BodyShopDropOut12
9 months
BodyShopDropOut12's Avatar
I don't know much about carbs myself :p , but I found this on ebay a lil while ago. Says performance if thats what your lookin for, but its pretty cheap.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33550
BodyShopDropOut12 is offline   Reply With Quote
Old 08-05-2004, 05:55 AM   #4
Nvbowtie
Nvbowtie's Avatar
Edelbrock 1406 200-250 bucks depending where purchased
In cold area - elect choke
warm area - no need
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
Old 08-05-2004, 10:05 AM   #5
screwballl
Tonawanda 454
screwballl's Avatar
i am waiting for my Edelbrock 600 to get here as we write, my rochester is slowly dying.
check these two numbers at www.summitracing.com : EDL-9900 and if it is stock intake, EDL-2697
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 08-05-2004, 05:55 PM   #6
stepside454
stepside454's Avatar
Personally I like a properly tuned Q-jet
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 08-05-2004, 05:58 PM   #7
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
With you being new to a carb get the Edelbrock 600 1406 (electric choke) You live in Iowa and will need it in winter. The 1406 is one of the easiest to tune and change out the jets, rods, and springs all while the carb is on the engine. It's a great carb for performance as well as daily driving.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 08-06-2004, 12:57 AM   #8
alpha_male0203
ok what is the differece from eletric and manual carbs sorry i am only 16 and jsut trying to learn now thanks
95 Chevy k 1500
Old 08-06-2004, 02:53 AM   #9
jimfulco
Me too.
jimfulco is offline   Reply With Quote
Old 08-06-2004, 04:15 AM   #10
TIMSPEED
TIMSPEED's Avatar
Electric Choke's work off of a eletrically connected metal spring. It's heated by the electrical connection. It runs for a "set" amount of time.
Whereas a Manual (sometimes called Hot Air Choke) runs off of heated air from the intake manifold. The Air reaches a certain temp, and flows past the spring, which works off of the ACTUAL heat in the intake.
Does that make it clearer?
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 08-06-2004, 04:36 AM   #11
BodyShopDropOut12
9 months
Electric have automatic warming chokes, where as manual has a lever you pull in the cab??? Am i wrong, or right?
Old 08-06-2004, 09:26 AM   #12
stepside454
TIMSPEED... you seem to be a little confused. A manual choke is just that, its set & unset maunually, with a hand operated cable. What you seem to be speaking of is mechanical
Old 08-06-2004, 10:26 AM   #13
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Im thinking divorced choke is what Tim is talking about, but I could be wrong.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 08-06-2004, 11:07 AM   #14
rockman20
"The dude abides"
rockman20's Avatar
That is what I call a manual choke. Electric has already been explained pretty well. I have that hot air choke on mine and will be replacing it in the near future. I am running an aluminum intake and in the winter time (in the Dakota's) there are times where it will heat up and the choke will go off but as soon as you start driving and the cold air gets in there, the choke comes back on.
What happens on this setup is much like the electric. You have the thermo spring that sits on the intake. As the intake heats up, so does this spring which begins to uncoil which slowly opens the choke.
Now there is also a version like this where they put a tube down into the crossover on the intake. So the exhaust gas is pushed around this tube. The air inside of the tube heats up and that goes up into a "cap" on the carburator where the thermo spring is at.
Manual I like best. You remove all of this thermo spring stuff and run a cable from inside the vehicle to the carb. When you pull the cable, the choke is on. When you push the cable, the choke is off. If you have ever used an old snowblower or lawnmower, they often times use chokes like this. Very simple and I like being in control of what I'm choking! Or who for that matter!
RockMan
1993 Chevy Silverado C3500 1 ton dually
1994 Honda Civic
1969 Oldsmobile Cutlass S
1953 IH Farmall Super M
New to the fleet:
1992 Subaru Loyal
rockman20 is offline   Reply With Quote
