Old 08-05-2004, 09:51 AM   #1
Bowtiefreak
Bowtiefreak's Avatar
Need help with cab mounts
Hey everyone,
I am getting ready to put my cab back on my frame this weekend and came into a snag. I know how the mounts go together but I forgot about getting the spacer bushings that go inside the rubber mounts. I don't have any at all so I will just make some here at the shop instead of trying to find some. SOOO the question is: What are the length of the spacers ? I am pretty sure that they are 7/8 round front and back and the front are a 9/16 hole and the backs are 7/16 hole but what is the length.
Also, what is the tq. spec (if any)
Can someone tell me?
Thanks alot
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 08-05-2004, 11:50 AM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Rears are 0.750 od x 0.563 id x 2.5 lg.
Fronts are 0.875 od x 0.750 x 1.95 lg.
I put about 2 coats of POR15 on mine so the dimentions are only approximate. I tried to round them a little. The fronts are oblong so it is really not that critical. You should be able to find some tubing or pipe that will work. The center hole just needs to provide clearance for the bolt.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 08-05-2004, 11:59 AM   #3
cduster
The ones I got with my kit measure to be 2.25" long with .75 id and .875 od. the other one is 2 3/16" with a .676 id and .875 od. I am assuming the thicker spacers go with the larger bolts, but could be mistaken. Kit didn't come with instructions.
Hope this helps, Dan
cduster is offline   Reply With Quote
Old 08-05-2004, 12:34 PM   #4
Bowtiefreak
Thanks guys!
I found out that LMC has them and to get them to me would be $45.00
I think I can make some for alot less, YA think, since I work at a machine shop.
