Old 04-05-2002, 02:16 PM   #1
Erl
Erl's Avatar
Post Removal of horn ring from steering wheel
Need to remove the GMC horn ring from the steering wheel to replace turn signal parts. How does it come off without destroying it.
68 GMC 3/4 4x4 Stepside
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
Old 04-05-2002, 03:17 PM   #2
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Post
Should just snap on and off. Pry from the edge gently and work your way around.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 04-05-2002, 03:18 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
Post
i assume you mean horn button/cap, its just held on with press fit rubber, it wil come off with fingers, you wont hurt it, trust me, lol you can just reach through the door without even being in the cab, and just pull it off, easycake.,
Randy- Lincoln, IL
r68c30@hotmail.com
71 C-10, trying to assemble....sigh..
parting out 5.0LTPI '81 cutlass supreme brougham
*Paint is overrated
© RSS Enterprises 2000
[This message has been edited by Fast68Chevy (edited April 05, 2002).]
Fast68Chevy is offline   Reply With Quote
Old 04-05-2002, 03:39 PM   #4
COBALT
COBALT's Avatar
Post
If it's NOT just the horn button then you have to remove the metal disk that acts as the connection to the cam underneath, the funky plastic piece (the loop with the three holes for the screws) and the housing the horn button snaps into. Just remove the three phillips head screws and everything else should fall out.
Then pull the steering wheel (with some cheap pullers). The turn signal switch will be in the housing in the column along with the top steering bearing, and all the bushings and crap.
Taking it apart is actually easy. Getting it back together and adjusted is a pain.
good luck.
'69 3/4 ton C20 2wd w/ 350ci/400THM and a wood bed!
'69 3/4 ton Custom 20 2wd w/ ORIGINAL 350ci/4sp Manual and a wood bed (parts beast).
Seattle, WA.
*See pics of my trucks and project at www.webshots.com!
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
