Gas Tank Filler Hose
OK, so where does one buy a 1 3/8" diameter filler hose for the gas tank? Every hose place I call has never heard of that size.
Toys: 72 K5 Blazer 74 Vette |
![]() Join Date: Jan 2000
You might try a marine supply house. Also I think Wes stocks it.
Its lookin' like a Blazer!
I read a post awhile back some of the guys bought hose from a place that makes hydraulic hose, its supposed to be the same type of hose. Any heavy equipment dealer should sell the hose.
Blazer takes 1 3/8 hose . How many feet do you want . I have about 2 feet left new . Jose
Thanks for the replies, and thanks for the hose offer Jose!
When I topped off my gas tank, I could always smell gas in the garage. I crawled under the truck and noticed a slight leak from the top of the tank, but couldn't tell where it originated. So I pulled the tank yesterday, and found the filler vent hose (the 1/2 " one) had a crack in it. I replaced all the small hoses, but couldn't find a filler hose locally. I closely inspected the old one and it has no cracks and is still flexible, so I siliconed it up to look like new and re-installed it. It looks like this hose will do until I pull the body off the frame and restore everything, which probably won't happen for a while. Again thanks for the replies.
Post Whore
![]() Join Date: Feb 2000
I finally found the hose at a local rubber hose company - none of the auto parts stores had the correct size and the one sold by the reproduction companies was way too large in diameter.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
![]() Join Date: Apr 2000
i got mine at napa..at 8.00 a foot ouch!!!!
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
filler hose
Hey Skid,
There is a place near me called THE BRIGGS COMPANY,3 Bellecor Dr. New Castle, Delaware. (302)328-9471 . Try them they should be able to hook you up with what you need. I bought a fuel oil hose from them and it was the correct size. Give them a try. hope i could help ya out, Tom |
This is what I've got...
'72 K5, known as 'the Fox.' |
