considering a 4/6 drop
hey guys, im the future.... 6 motnsh at the msot i hope,. i want to do a 4/6 drop and put spem disc brakes up front. Right my truck hs been lowered 2 inches all the way around. i have some spindles, but im nto sure if the are stock hieght or 2 1/2 drop. the truck was liek thsi when i got it. for thsoe of you that have a 4/6 drop on a 67-72 how did the ride change. some people say ill regret it becase il drag my a$$ everywhere and that kind of stuff. nad hwo is the ride after the drop. right now the rear of my truck is kind of loose and well i dont liek it that much. I was thinking that if i did a 4/6 drop, up frotn id only need the drop spindles, and im not sure what id need out back. woudl i need longer tie rods? or any other stuff liek that. thanks for the help, and sorry for making all of you read so much
I used Early Classic's kit to lower mine 4.5/6 & the ride is great. I've bottomed out in the front, driving like a jack-a@@ over very rough roads and I think the only reason that happened is because I'm running a short diameter front tire on a 15" rim. With ECE you can get a dropped spindle that will accept the stock 1970 tie rods & ball joints. If you already have the 2" dropped springs up front, just get their dropped spindle and disc brake kit, or you can piece the disc brakes together using 71-87 stuff. As far as the back is concerned get their 6" drop kit that comes with springs, shocks, shock relocators, and super panhard bar. While I had mine apart, I went ahead and changed the trailing arm bushings over to poly-urethane pieces which also came from ECE. I have had no complaints with the ride or the service I have gotten from ECE. And tell Dave or Stan that Steve from Louisiana says Hello, and is saving up for his next purchase from them.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
Watch out for your cornhole !
![]() Join Date: Jun 2003
All of my trucks get the 4/6 drop. You will not be sorry, I never am..
These are my last three trucks, all with 4/6 drop.
