View Poll Results: Do you think its a good idea?
Yea 5 35.71%
No 1 7.14%
WHATS AN MRI? 8 57.14%
Voters: 14. You may not vote on this poll
Old 08-05-2004, 11:58 PM   #1
guitarornothin
RUNN over AGAIN!!!
guitarornothin's Avatar
Mri for gasket matching
I taped a Mri over the intake ports of my new Airgap intake , then I shoved my fishes nightlight up the hole.
Next you use a regular scraper razorblade and carefully cut out the ports. Next place over your intake ports of your heads and grind till they are exactly the same. Perfect!
Just hope somebody in the house is a gimp and has a stack of old MRI's to use.
67-72 TRUCKS ROCK
70 SWB shaved and a 72 front clip.and a poly tank.
Peep mirrors and a BIG BLOCK 468 in the making.
XNXNXNXNXNXNXNXNXNXNX
,/. EMAIL ME HERE!, Dont pm me please
guitarornothin is offline   Reply With Quote
Old 08-06-2004, 01:46 PM   #2
meathead95
computer illiterate
meathead95's Avatar
ive seen people do that with intake manifold gaskets before but my question is how are you sure you are going to get them taped up in the exact spots on the heads
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 08-06-2004, 02:09 PM   #3
guitarornothin
RUNN over AGAIN!!!
Post
to get it lined up PERFECT you use the bolt holes. i cut those out too...
and an MRI(those that dont know) is a Medical X-Ray. THOSE were of my back.
67-72 TRUCKS ROCK
Old 08-07-2004, 02:18 AM   #4
guitarornothin
RUNN over AGAIN!!!
why isnt anyone commenting on this..then...
TTT
67-72 TRUCKS ROCK
Old 08-07-2004, 12:03 PM   #5
bmg
bmg's Avatar
why would you do it? Seems they would melt from the heat.
bmg is offline   Reply With Quote
Old 08-07-2004, 02:37 PM   #6
meathead95
computer illiterate
meathead95's Avatar
hes just using them as a template to get the intake/head ports identical more flow more power we used to do the same things on our dirt track cars but we used the gaskets for templates same difference as what he is doing it works great i just had my head in my a$$ when i responded the other day it must have been the mri papers that threw me off anyway ttt for yah
72 2wd blazer
72 swb 4x4
Old 08-07-2004, 03:28 PM   #7
silvertonguedevil
silvertonguedevil's Avatar
I don't see why not. That should work out pretty good. That's port-matching at it's finest.
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 08-07-2004, 03:30 PM   #8
jorgensensc
jorgensensc's Avatar
You just have to make sure youtransfer the same gasket with the correct (opposite)side to the intake as you had on the head. Had a buddy not pay attention and the intake and head didn't match at all.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 08-07-2004, 03:32 PM   #9
cdowns
cdowns's Avatar
looks like an extra unnecessory step to me i've always done it directly on the gaskets
Old 08-07-2004, 10:52 PM   #10
Stroker
I like to think of it as port matching instead of gasket matching. I don't think the gasket manufactures give a lot of though to flow when they design a gasket although the gasket's port sizes are based on typical ports so they are close. Sometimes when using an aftermarket intake with stock heads the head needs a little work to open up the port. With larger port heads the intake runner can may need a little porting. Just don't get carried away and create a bellmouthed area which will kill the velocity in the middle of the port. You should try to keep the intake manifold openning about .050 larger than the head openning to allow for any misalignment during assembly. When the ports are finish then I check the gasket to be sure it doesn't extend into the port area and trim it with a razor if it does.
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
