Took my truck out for a ride today with the added timing
All I have to say is...WOOOOOOO!!!! The thing pulls NOTICEABLY harder! For some odd reason, now the idle speed screw (the one that adjusts the throttle plate) actually REALLY affects idle speed. I turned it like a HALF turn and it adjusted the idle down to 700rpm in drive. WORKS FOR ME!! I'll report back on the gas mileage.
Thought I'd post about this, since it's the first time I've driven the truck in about a month. ![]() |
nice.. timing makes a massive difference in how an engine runs.. how many degrees of total timing are you running now?
Webmaster: www.h-body.org |
Hahah, hey Colin, didn't know you were a member HERE too.
yeah, it should be around 36 total.. 6 degrees makes a huge difference
![]() Yeah, I've been a member since like 2002 but haven't posted much. I used to post quite a bit when I was working on the restoration of my 70 CST big block shortbed ![]() Do you still want the C4 doors? later! colin
california fill
36 - 28 = 8 but who's counting?
36 degrees, thats it? bump it up a little higher ![]() pc |
LMAO... man, now you know why I changed from a Biology major (too much math) to English..
I typically adjust my timing until I hear ping then back off 2-3 degrees with my timing light..
