Right turn Clyde
Best 1/4 ET
16.285 @ 83.04 RT - 1.577 I was very very tired 60 - 2.386 330 - 6.819 1/8 10.425 @ 67.89 Best 1/4 trap speed 86.76 @ 16.356 RT - 1.408 60 - 2.722 330 - 7.184 1/8 - 10.711 @ 69.65 Best RT of the day of 5 runs 1.331 next time I will be better rested. ![]() Worst run 17.401 @ 70.79 RT - 1.555 60 - 2.515 330 - 7.020 1/8 10.936 @ 62.15 Engine: 355 Cam: LM1 Heads: WP s/r torquers Rocker: CC roller tip 1.52 Intake: 2101 Edelbrock Carb: 1406 Edelbrock Headers: Hooker Competition, dual exhaust, two catalytic convertors Trans: TH400, stock stall, transgo shiftkit, remote filter Rear: 10 bolt 3.07-8 its 1982-7 used from junkyard Tires: 235-75-15 Bridgestone APTs The problems lol Blown front intake seal #4 cylinder intake valve rocker arm not oiling (bad lifter or flat cam lobe) Plugs are very carbon fouled (not real sure why? carb or ignition probably) timing 12 btdc @ 800 rpm - starting to think the distributor is a tooth off from the way it sets. Bed had a set of tires in it Lose negative battery wire That's about all I can think of I knew about the problems before I went. Just wanted to see what it would do. I plan on fixing what needs it then running again. It still feels pretty good to me for what it has and what it does. ![]() I had fun doing it, even though I was the slowest one there. It was my first time running ever and forsure wont be the last. ![]()
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
Right turn Clyde
So is my trap speed good for what I have? Im not real good at reading into the slips just yet.
Hmm..I GUESS it's good.
Just for reference, my stock 93 Saturn SC2 automatic, in DECENT weather, trapped 85mph. But you have a lot of things going against you. LWB, 3.07's, TH400, Pegleg, and maybe not decent weather. |
