Old 08-06-2004, 06:49 PM   #1
cablecam
What hose is this? [PIC]
This hose started leaking on me. I think it's just old and cracked. Could someone tell me what hose this is, and if it's easy to replace, any help is appreciated. thanks.
-78 Chevy 4x4
-- American Racing rims
-- 33x12.5 tires
-- and other misc stuff...
-- work in progress
- 94 Probe daily driver...
cablecam is offline   Reply With Quote
Old 08-06-2004, 06:51 PM   #2
ocbaud
Garage Queen Material
it goes from the fuel pump to the metal fuel line
ocbaud is offline   Reply With Quote
Old 08-06-2004, 06:57 PM   #3
cablecam
Thanks, is this an easy fix? Reason I ask is I just put this truck in the local newspaper for sale, and it sucks that this had to happen today of all days.
-78 Chevy 4x4
-- 33x12.5 tires
-- work in progress
Old 08-06-2004, 07:01 PM   #4
ocbaud
yeah, get some, i believe 3/8" fuel hose and cut it to the size you need and replace it.
Old 08-06-2004, 07:03 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Unless the clamps are hard to get at it's an easy fix. First try tightening the clamps and see if that stops the leak. If it persists get a 12" piece of 3/8 fuel line, cut to fit and swap them out...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-06-2004, 07:46 PM   #6
cablecam
Do these things usually fit on each end of the fuel line and the pump easily? My problem is, Its impossible to see each end of the hose and exactly how it connect. I stuck my hand down there and it feels like a normal metal hose clamp around each end... My main concern is I don't wanna take it off then not be able to get it to a shop to fix or not be able to start it up to show someone who wants to buy it.. but thanks for all the help.
-78 Chevy 4x4
-- 33x12.5 tires
-- work in progress
Old 08-06-2004, 07:53 PM   #7
76HighSierra
DAMN, I love Big Blocks!
76HighSierra's Avatar
You'll best see it from underneath. Be sure to wear safety glasses!! Gasoline in the eyes is quite painful. Remove it, measure it's length and cut it from a new peice of 3/8 rubber fuel line. Also, get yourself some new hose clamps for the re-install. try to get the kind that are "smooth" on the inner diameter, so as not to damage the fuel line upon tightening. Good luck!
Marc Bona
Hobbs, New Mexico
1976 1/2 ton GMC High Sierra.
454 c.i.d./ TH400. *Soon to get a mild warming over.*
3.40 rear.
76HighSierra is offline   Reply With Quote
Old 08-06-2004, 11:42 PM   #8
Russell
Professional Grade
Russell's Avatar
Thats your fuel supply line, if you take it off, you won't be able to run the truck to show to potential buyers, but it won't (I can almost guarantee you) give you any problems when you change it out. Just go buy some 3/8 fuel line, and cut it to fit, problem solved
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 08-07-2004, 11:16 AM   #9
cablecam
Thanks guys for the help. I just put it in 30 min ago. Hardest part was tightening the clamps in the small little space.. sorta ackward, but nonetheless I appreciate the help.
-78 Chevy 4x4
-- 33x12.5 tires
-- work in progress
