Old 08-07-2004, 12:11 AM   #1
BUXMAN66
go bucks!
Question angle (in degrees) of rear output shaft to the rear diff.?
have'nt been frequenting the board much lately, as i've been doing a build-up of a '49 gmc 1/2 ton shrtbd. put a new 350/350 combo in w/ a 6" drop tranny cross-member. front sub-frame from a '76 chevy nova.... can't remember exactly the angle i need to be at for the rear pinion. i keep thinking it's 5-9 deg. but not sure.... anybody happen to remember? i got everything all finished as far as the engine/tranny being mounted and i have the drive- shaft in and hooked up to the rear diff. the angle coming outta the out-put shaft into the u-joint of the d.s. don't look right though. i put my magnetic angle finder on the d.s. and i'm getting 3 deg. positive angle.... and i think i need 5-9 neg. thanks to anyone out there....
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 08-07-2004, 01:00 AM   #2
BUXMAN66
go bucks!
ttt
Old 08-07-2004, 06:11 AM   #3
JimKshortstep4x4
Smile
The only specifications that I have are for a 65 Impala but I believe that they are applicable. The range is 0 to 4 degrees. Both front and rear angles should be the same + or - 1/2 degree. My recollection is that 2-4 degrees is the preferred range because the needle bearings will rotate more than at say 0 degrees, so they last longer. Vehicles for drags run different angles but I don't have those specifications.
Jim
Old 08-07-2004, 08:33 AM   #4
Phuloi68
Some favorites I've saved from this board and others.
www.drivetrain.com -.do a search for driveline angle
www.carcraft.com -.do a search for driveline angle
www.clubfte.com -.select member sites. scroll to jniolon site and select. go to driveline phasing.
This should help you out. Hope those sites don't mind me passing this info on.
Phuloi68
Indy survivor
Norwood survivor
Big Sandy survivor
for those who fight for it...
F R E E D O M
has a price the protected
will never know.
Phuloi68 is offline   Reply With Quote
