08-07-2004, 12:53 AM | #1 |
Lovin' Life in Miss.!
Big deal or no big deal?
Just kinda nosin around before I start cleaning and found this at the right forward crossmember. To me, it looks like the rivet wasn't set properly. Just drill it out and bolt it together?
Truck was hit in the right front by unknown po. Not Bad though. Thanks for any input. Rich
The truck... you hear that? No really, you did hear that?!!! |
08-07-2004, 01:01 AM | #2 |
Certified Chevy Man
Yeah, that'd be the sway bar bracket. If you like a level ride I'd fix it. Yeah, drilling it out and putting a bolt in it would fix it right up. Now if it was a 4x4, I'd say take it off cause it's worthless.
68 Chevy CST (327,TH400) 3/5 drop lots of fun stuff 71 Suburban 4x4 (350,TH350) 7" lift 37's, D44/14 bolt and other sorts of goodies, lockers front and rear, flexes 40", 895 RTI score Check out my web site!!! http://www.geocities.com/cst68chevy/ |
08-07-2004, 07:34 AM | #3 |
Watch out for your cornhole !
3/8 bolt.
That's the typical procedure when you replace those brackets, grind and punch rivet out and replace with grade 8 bolt.
08-07-2004, 07:23 PM | #4 |
I had the same problem with my 71, 1/2 ton. It wasn't hit but the rivet was loose. I drilled it out and replaced with a bolt years ago. Has me wondering if it just wasn't installed right from the factory or if it stretched over time? Interesting to see others having the same issue.
08-07-2004, 10:14 PM | #5 |
blood type; Retumbo
I saw that same kind of condition the other day at work on a late 90's Ford pickup! my guess is that they were installed on a friday afternoon.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
