Balance Question...
How critical is it that all rods be perfectly balanced in a 350? I may have mixed up which rods go where, and I even bought one from a junkyard because I bent one. Are they all a little different weight, each balanced to that part of the crank?
I have all new bearings, pistons and rings, the block was bored, and the crank was turned .010 undersize.
1972 C10 1972 C20 ![]() |
I should also add that it is NOT a high RPM racing motor. It is going in my truck, which will probably never see more that 4500-5000 RPM. The cam is only good to 4600, I built it to pull.
Ttt
Unless you have a really heavy rod its no big deal. The factory does not balance the rods when they make the engines, excpet maybe the Vette and Caddy engines. They are all probably within a specified range. Make sure the junkyard rod is ok and straight, might want to have all the rods resized also.
72 Chevy C20, SOLD (Dang it.) 09 Challanger RT six speed in all black. 74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power. 73 C10 long bed, 350/350 combo, nice shape. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
For a street engine, you'll never know the difference.
I've built engines that my buddies called "sweep the floor motors" where I just gather up whatever usable parts I can find and put them together with new bearings, rings, and gaskets. Suprisingly, they are usually some of my better running ones. I guess it's the looser tolerances inside.
Thanks, that what I want to hear. I really didn't want to tear it back down and buy new rods...
Cantankerous Geezer
Unless you plan on turning over 6,000 rpm it's not a concern. No problem for your engine.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
