Need 4X4 ball joint advice/help
I think my 72 k-5 has a bad upper ball joint on the pass. side. Grabbing the top and bottom of the tire I can wiggle it a little in and out. While it was jacked up about 1" off the ground I put a bar under the wheels and pried upward on each wheel, there was a little up and down movement in the lower joints. (both driver and passenger side). Does this mean they're bad also? OK, if I try to replace these myself do I have to remove the whole hub assembly and axle or can these be replaced whithout taking everything apart?
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible. |
![]() Join Date: Mar 2003
The whole knuckle has to be removed from the axle and then they can be pressed out
