View Poll Results: transmission type | |||
700r4 transmission |
19 | 70.37% |
350 transmission |
8 | 29.63% |
Voters: 27. You may not vote on this poll |
transmission type poll
As most of you know, I have a 84 suburban with a 350 motor. I know the 700r4 transmission needs rebuilding. I do a lot of towing with this suburban and am deciding whether to rebuild the 700r4 trans, or put in a 350 trans with a 9 inch tailshaft.
I am letting the majority decide for me on which one to go with. Thanks for the help Tommy Davis
junkyardpartseeker@sbcglobal.net |
driving is in my blood
Why would you want to loose overdrive? I don't get it.....
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Not wanting to loose the overdrive, just wanting to know which one would be better on the heavy towing it will be going thru. I am not too familiar with them, so I thought I would let the ppl here decide for me.
Thanks for the help. Looks like I will try to get the 700r4 rebuild. I know it is a 85. Is there other years I should look at that would be better? I am not running any emissions and am not sure what all I would need to install it after rebuild. Tommy
ROCKET POWER!
If possible get a 1988-1992 year 700R4 from a K-truck (4wd) and have it rebuilt.
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
You can update your 85 transmission with later parts. But I would just add extra clutches in the 3rd-4th gear, add corvette servo, .500" boost valve, shift kit setup for towing, good transmission cooler and a lockup kit so you can lockup the torque converter in 3rd gear. You could also just get a later model valve body too I think, thats the only real difference bewteen the early and later model transmissions, I don't remember if the valve bodies interchange though. You could also upgrade to a heavier sprag but for our year 700r4 its kind of expensive because the whole thing needs to be replaced, also the sun gear shell can be replaced with a stronger unit.
How much weight are we talking about here?
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
Not sure on exact weight. I do know my wife has a 26ft trailer loaded with her flea mkt items. Just want to be prepared if she gets more in there.
Tommy
Do get a newer style 700R4, don't bother updating yours. It should be cheaper to just buy a core newer model and rebuild it instead of updating the old one.
a 700R4 is suposedly a turbo350 with an overdrive, i would go 700R4 all the way, i've got one in my truck and i love it. just gotta build them right if you want them to last
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
I belive if i was wanting a heavier duty for towing id put in a th375 or th400
BAD BOW-Silverado XST
Rebuild any core from 85 and up. I have an 85 and beat it pretty good. No problems with a stout rebuild.
