Old 08-07-2004, 06:14 PM   #1
moodyholler
moodyholler's Avatar
Need an axle!!
Lh rear axle is trashed. I have access to a 74 axle and a 70 axle. Will either of these fit my 4x4 72? Both are from 4x4's. Also will an 88 power steering box from a 4x4 blazer fit a 72 4x4 blazer? Will it be variable ratio? Thanks, J=moodyholler
1998 WRANGLER I-6 auto
1972 LWB FLEETSIDE
1968 GMC SWB STEPSIDE
1994 C-1500 SWB 4.3 5 SPD
moodyholler is offline   Reply With Quote
Old 08-12-2004, 10:09 PM   #2
earl87gta
earl87gta's Avatar
Feel like a road trip to TN I will have an extrta set of axles and a steering box. Let me know if I can help.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 08-12-2004, 10:10 PM   #3
earl87gta
earl87gta's Avatar
I almost for got they came of a 72 blazer
Earl
Old 08-13-2004, 09:18 AM   #4
JimKshortstep4x4
Smile
moodyhollar,
If the 74 rear end is a 12 bolt 4x4 rear end the axle will fit. The 70 could have the shorter axles in it . If you measure between the backing plates and the measurement is the same as on your Blazer then the axles will fit.
Jim
Old 08-13-2004, 11:57 AM   #5
easy_13
Earl87gta,
What gear ratio is it? If it's 3.73, I might be interested if the price is right.
easy_13 is offline   Reply With Quote
Old 08-13-2004, 02:38 PM   #6
Grim Reaper
74 shafts will work. You might want to get the 74 front axle shafts as well. they ran a larger u-joint and are stronger.
Steering box is a bolt on. It will be a nice upgrade. It's variable close ratio. Be carefull that first turn so you dont flip the truck.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 08-13-2004, 03:08 PM   #7
moodyholler
thanks all!!!
I got it back together a little while ago and just went out for a run. Freind of mine had a brand new axle from a 79 and I put tit in. Earl, will be down that way on Sat. the 21 if all goes well. Mine does have the small u-joints in the front now. Will try to salvage 74 model axles and lay them up for future use. Thanks again for all the help. moodyholler
1972 LWB FLEETSIDE
