Desktop Dyno?
Is there a program that will estimate the horsepower and torque of your engine if you give it all the specs? If so what is it called, and can I get it for free? If one of you has the program(if it exists), can you see what this would be? :
---1972 Chevy 350 2 Bolt Main--- -Bored to .030 over(355) -Crane Energizer Cam & Lifter Adv Dur Int 266 Exh 266 Dur @ .050 Int 210 Exh 210 Deg Lobe Sep 110 Valve Lift Int .440 Exh .440 -Cloyes Double Roller 3 Key-way timing set --Hypereutectic Pistons -Moly Rings -Edelbrock 600cfm electric choke carb -Edelbrock Performer Intake -Hedman Hedders This should be a pretty average setup. What do you think I've got? 300hp maybe?
1972 C10 1972 C20 ![]() |
The oddest Todd around
I think you'll also need to know the specs on your heads as well.
Todd |
Keep On Truckin'
The Desktop Dyno is not real accurate from everyone I have talked to. I had a copy several years ago and ran the numbers for my Muskrat through it and came out with numbers that were insanely high.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
I'm not sure exactly with the heads. All I know is that they are the stock heads on a 1972 350 from a C20 with a 2bbl carb on it.
hey chevelle454 check your private messages
Desktop Dyno 2000
Stock heads-headers thru mufflers-guessing 8.5to1 ratio.
HP@ flywheel---------Torque@ flywheel RPM 2000---136-------------357 3000---205-------------358 4000---264-------------347 4500---270-------------315 5000---254-------------267
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
