Alignment shims Pic.
Well so far I am 0 for 2 in finding a shop that can put in alignment shims that will stay in. Can someone post a pic a 67 / 68 1/2 tons alignments shims?
Thanks |
Try some shims like these they won't come out.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
NeonLarry
It doesnt look like they will at all ![]() Btw nice engine. Thanks |
Cantankerous Geezer
In my forty-some years of driving, working on, and being around Chevies I've never seen a case of alignment shims coming out. Have I been that lucky?
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Too Many Clubs Club
I asked the guy who was showing that frame (72 Blazer) about those when I took that picture. He said they were one-off pieces made especially for that truck. However, he also said he could make them again for me, if I sent him the specs (thickness).
His business card reads: Suspension Werks Michael "Opie" Brinkley 713-542-1162 Hope that helps.
How I installed my air bags... |
Fred
It must be a combo of you being lucky and me not being lucky ![]() Mrshelly Thanks for the info. If I strike out in my area I will pm you. |
Have you looked at machine washers? They come in various thicknesses.
Like Fred I have never seen the shims come out either. Jim |
Did he say they fell out or you just went out of alignment? With all of the trucks on the road if that was a problem with them falling out there would have been a recall on that as a safety issue. Have you counted the shims and they really fell out or are you taking the shops word for it. If the alignment goes out and the shims don't fall out you have control arm bushings that are worn. If they are falling out the Nut isn't being tightened enough or is stripped and is backing out.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
I buy the shims that have the frying pan handle with the hole drilled in them. I then lockwire them with stainless lockwire. Doesn't really accomplish much, but it does keep them neat, and looks trick.
Toys: 72 K5 Blazer 74 Vette |
![]() Join Date: Aug 2001
![]() I USUALLY USE THESE SHIMS WHEN I BUILD A TRUCK THAT IS LOWERED MORE THAN 2 INCHES IN THE FRONT, SO I DON'T HAVE TWO USE TOO MANEY OF THE SMALL STEEL SHIMSWHEN I GET THE FRONT END ALIGNED. I TAKE AN OLD UPPER CONTROL ARM SHAFT, MILL IT TO ABOUT .625 THICKNESS, & CUT OFF THE THREADED ENDS. (THANKS TO MY G/F s SON IN LAW FOR DOING THE MACHINE WORK FOR ME) ![]() ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
i had some fall out. i replaced the lock nuts because they were original
68 short step, 406/700r4, 9" w/discs. |
