Old 08-07-2004, 11:41 PM   #1
TIMSPEED
TIMSPEED's Avatar
Who's headlights flicker at idle??
For some reason, if I set the idle on my truck to lower than 750-700rpm, the headlights flicker and the tach bounces. If I keep the idle (in gear) at 750-700, it's fine. Does anyone else's truck do this, or maybe is mine just not right? I'm thinking maybe the 65amp alternator might not be enough...but I mean, I'm ONLY running the headlights off of it...
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 08-08-2004, 12:48 AM   #2
rage'nrat638
rage'nrat638's Avatar
SOUNDS LIKE YOUR TIMING IS SET TO HIGH
DOHOOOOOOOOOO
rage'nrat638 is offline   Reply With Quote
Old 08-08-2004, 06:04 AM   #3
TIMSPEED
TIMSPEED's Avatar
My timing is set at 12º @ 800rpm, 36º @ 3000rpm.
See Them Here
Old 08-08-2004, 09:46 AM   #4
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
I'm sure it was only a joke....
A higher amperade alt will not help in this case, it would actually make it worse. As the alternator speed slows down, the output voltage drops also. Assuming the alternator works fine at higher speeds it is working fine. It's just a fact of life. If you are trying to get the truck to sound more rumpity-rump at idle you will have to live with the flicking lights.
NeCrOmAnCeR is offline   Reply With Quote
Old 08-08-2004, 10:26 AM   #5
Grim Reaper
The copper got old and it's not as conductive.
Check your grounds to the core suport.
If they are all good then it hownestly is the 30-40ft of wire and 20 or so connections between the battery and the head lights are causing a voltage drop. To test that start the truck and turn on the head lights. Check the voltage at the battery and check the voltage at the healights. Your probably going to find a 1volt drop.
Painess sells a head light kit that puts some high quality relays and lager gage wires and pulls the power straight from the battery. It then uses the old wires as the trigger wires for the relays. BobbyK on the 67 forum has posted how to make your own kit on ck5.com and I'm sure he has also posted it here.
http://www.4crawler.com/4x4/CheapTri...adlights.shtml Is a little more info about the rewire.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 08-08-2004, 01:32 PM   #6
1972C10
1972C10's Avatar
I idle most of mine at 1000
1972C10 is offline   Reply With Quote
Old 08-09-2004, 07:54 PM   #7
85Silveradoin04
I'm assuming this is out of gear right? Thanks
85Silveradoin04 is offline   Reply With Quote
Old 08-09-2004, 08:00 PM   #8
Russell
Professional Grade
Russell's Avatar
Mine idles at about 700 rpm out of gear, and about 500 in gear, I found that it was clunking something nasty when I dropped it into gear when it used to idle about 800 - 900 in gear, and 1100 - 1200 out of gear. It idles very very smoothly at 500 rpm, and other than the headlights flickering a bit, it has no issues with it.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 08-09-2004, 08:34 PM   #9
TIMSPEED
TIMSPEED's Avatar
Your tach doesn't go crazy?
See Them Here
Old 08-09-2004, 09:01 PM   #10
Russell
Professional Grade
Russell's Avatar
I don't have a tach in there right now, got one on the way, but I'll probally run the power wire to the tach directly from the battery with an inline fuse to get around this problem.
Old 08-10-2004, 05:51 PM   #11
1972C10
1972C10's Avatar
Yeah On a stock engine I may idle them a tad lower But All my hotrods i idle at 1000 I find that when you idle them low trying to get more cam sound they will have lower oil pressure. And dont seem to respond as well
Old 08-10-2004, 08:26 PM   #12
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Get a bolt on 84-86 Camaro 94 amp alternator. I love mine.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 08-10-2004, 10:19 PM   #13
75-K5
Bucket of Bolts
It might be but I have been told that setting idle around 1000 in P/N will keep the plugs cleaner. I like my automatic-equipped trucks to idle at 1000 in park and my manual rigs to idle in the 700-800 range in neutral. Can't do much about EFI trucks though, my '87 idles at 700 warm in park.
This is the project that never ends, yes it goes on and on my friend....
75-K5 is offline   Reply With Quote
Old 08-11-2004, 01:45 AM   #14
1972C10
1972C10's Avatar
Yeah ive been running one of them for a few years mine came off a 84 T/A With the H.o Im about to loose it due to a later model pulley swap Its been a good one always keeps me at about 14.5 volts at idle Ive acutally put new brushes in it due to wear and still going strong.
Old 08-11-2004, 02:30 AM   #15
aliencheyenne
Cheaper than a new alt, run a couple of relays and have the headlights run off the battery. Wiring diagrams are all over the net, just goggle it.
aliencheyenne is offline   Reply With Quote
Old 08-11-2004, 02:31 AM   #16
TIMSPEED
TIMSPEED's Avatar
It's not just my headlights though...ALL the lights flicker. (Headlights, Interior Lights, Guage Lights) it doesn't bother me..it's just that my tach goes crazy. I may have to wire my tach to something other than the fuse block.
See Them Here
Old 08-11-2004, 05:11 PM   #17
RockHQ
ROCKET POWER!
RockHQ's Avatar
I can assure you that any carbon deposits the spark plugs might accumulate during idling are burnt off during acceleration, so from that point of view it's BS. Unless you like to idle your cars for extended periods of time.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 08-11-2004, 11:03 PM   #18
SanitysBane
mine never flicked, but i also has an altinator off of an 88, so not shure there
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
