Old 08-08-2004, 03:06 AM   #1
ryan68
Certified Chevy Man
ryan68's Avatar
NEED HELP FAST!!! OIL-PRIMING only worked on one side.
So I just got my engine all together, yeah. Went to prime it before I put the intake mainfold on or put it in the truck. I have oil out of every pushrod on the driver's side, absolutely nothing on the passenger side, what's the problem?????? All help is much greatly appreciated.
68 Chevy CST (327,TH400) 3/5 drop lots of fun stuff
71 Suburban 4x4 (350,TH350) 7" lift 37's, D44/14 bolt and other sorts of goodies, lockers front and rear, flexes 40", 895 RTI score
Check out my web site!!! http://www.geocities.com/cst68chevy/
ryan68 is offline   Reply With Quote
Old 08-08-2004, 06:59 AM   #2
JimKshortstep4x4
Smile
That is rather strange!
What is your oil pressure running at when you are spinning the oil pump?
Have you loosened the rockers up on the left side?
The rear cam bushing is not in position or the left front oil galley plug has come out, (two possibilities).
Good luck,
Jim
Old 08-08-2004, 07:32 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Are you using a distributor housing when priming? That is need to direct the oil to the upper engine area. (you would have to convert an old distributor into a priming tool)
If you are using a distributor, does it have a full groove going around it on the lower shaft? If not, turn it to another position and try again.
I know some of the 348/409 Chevy distributors didn't have the full groove and if not installed correctly, no oil would get to the right side.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 08-08-2004, 08:14 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Bob is on the right track.
You must use a housing on your pre-oiler to effectlively prime both sides. The oil passage on the outside of the housing has to be in place for the oil to be channeled to the other side of the engine.
If you use one of the screwdriver shaft kind of deal, without housing around it, only 1 side gets oiled that way. It's one of the seldom known facts of Chevy engines. I shake my head every time I see one of those cheap pre-oilers without the housing.
Old 08-08-2004, 12:26 PM   #5
ryan68
Certified Chevy Man
ryan68's Avatar
Thanks guys, I'll try that. But I don't have an old distributor. And I want to do this before I put the block in the truck. Should I just put my distributor in and hook 2 wires to a battery and crack it over without plug wires and stuff?
Old 08-08-2004, 12:29 PM   #6
ryan68
Certified Chevy Man
ryan68's Avatar
I other thing, this was after a couple of minutes. And I was turning the engine by hand while doing it. I used a piece of conduit with a big screwdriver hooked to a drill on the end to keep the screwdriver on the shaft.
Old 08-08-2004, 03:00 PM   #7
bobs409
bobs409's Avatar
It won't matter how long you spin it, without the housing, it won't reach the top of the engine.
You could either buy a primer tool that has a partial housing on it or perhaps rent or borrow one. Try Autozone, they loan tools out for free.
Bob
Old 08-08-2004, 07:46 PM   #8
ryan68
Certified Chevy Man
ryan68's Avatar
Replace my 1/2" conduit piece with an empty distributor housing, WHALA!!!!! Everything has oil now, thanks guys.
Old 08-09-2004, 08:12 AM   #9
bobs409
bobs409's Avatar
Glad it worked for you. Now you can breathe easier.
Bob
