Old 08-08-2004, 12:21 PM   #1
ocbaud
Garage Queen Material
replacing parking brake cable???
my cables are sticking really bad. i cant use my parking brake anymore.
would places like autozone carry them? and how hard are they to replace?
ocbaud is offline   Reply With Quote
Old 08-08-2004, 01:14 PM   #2
RockHQ
ROCKET POWER!
RockHQ's Avatar
If you're talking about the rear axle cables, they're very easy to change. After removing your wheels, take off the drums, disassemble the brake shoes, release the cable ends from the parking brake actuating levers, crimp the cable housing ends and pull through the backing plates. At the frame side, there should be a pin holding the cable housing to a frame bracket, remove the pin and you should be able to pull out the cables. The other end of the cable is very simple to loosen, just look at it and you'll see.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 08-09-2004, 08:17 AM   #3
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
GOt mine last year at auto-zone. Cheap too.
NeCrOmAnCeR is offline   Reply With Quote
