Old 08-09-2004, 01:04 AM   #1
Russell
Professional Grade
Russell's Avatar
Odd Question for you guys...
Hey guys, two questions here, #1 -- Do the newer fuel injected vehicles have some sort of a butterfly valve on it somewhere to restrict airflow to control the motor's RPM, or is it now done entirely based on the amount of fuel the injectors put it?
And #2 -- Does a diesel motor have the injectors directly in the cylinder, or are they in some sort of a pre-combustion chamber or something?
My father and I got into a disscussion tonight, and he feels that none of the newer vehicles have butterfly valves on them, which doesn't make sense to me, since the vehicle is run based on how much air is entering it as far as I know, and that diesel injectors inject directly into the cylinder. I dunno who is right, so we both decided that we'd let you guys decide
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 08-09-2004, 01:16 AM   #2
ocbaud
Garage Queen Material
i thought that the throttle body controlled the air and fuel amount??
ocbaud is offline   Reply With Quote
Old 08-09-2004, 01:22 AM   #3
1972C10
1972C10's Avatar
If your talking about How it raises rpm it has a throttle body most have one single blade The diesels i have seen have injectors on the intake kinda like powerfogger setups for Nos.
1972C10 is offline   Reply With Quote
Old 08-09-2004, 01:33 AM   #4
Russell
Professional Grade
Russell's Avatar
ah ha, so I am right then, lol
My father figures that the comptuer controls RPMS soley by adjusting the amount of fuel injected...
Old 08-09-2004, 02:09 AM   #5
plumbcut
california fill
there is definately a butterfly (throttle) valve on all gasoline engines.. throttle position, air flow, engine rpm, among other things are factored into the signal that the computer sends to the injector, so that the appropriate amount of fuel is given to the engine...
as for the diesels, there are indirect, and direct injection types.. the differences between the two- i dont know. but I do know that with direct injection type, its injected into the CC just as the name implies. im sure arveetek or someone with some diesel knowledge will chime in
pc
plumbcut is offline   Reply With Quote
Old 08-09-2004, 08:01 AM   #6
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Gasoline engines use throttles as mentioned. The computer can control idle speed using the "Idle Air Control" a small stepper motor which opens a small air passage allowing more air into the engine. The computer also uses various other sensors to monitor air flow into the engine at off-idle speeds to compute the correct ammount of fuel to add.
The majority of diesels you will come across are direct injection where the injector places the fuel directly into the cylinder. On the newer computer controlled types the duration and ammount of fuel are controlled by the computer to give the desired speed and power. On older engines, individual injectors are actuated with a camshaft lobe and ammount of fuel is controlled with a "rack" which rotated a sleeve in each injector that opened the drain port. Others use a central injection pump which does all the above and sends the pressurized fuel to each injector through steel lines. Like I said above most diesels are direct injection, there are a small ammount which use pre-combustion chambers in the head. The purpose is to cause greater "swirl" and allow more complete combustion. It was apparently found that the same thind could be accomplished other ways.
Hope this helps.
NeCrOmAnCeR is offline   Reply With Quote
