![]() Join Date: Sep 2002
No not that kind of rearend. I have a 69 3/4 ton and i would like to know if it is a dana or rockwell. it is kind of a round back cover. where would i find the gear ratio on it. the glove box decal is completly faded.all help would be greatly apreciated thank,s big lou.
Certifiably crazy person |
![]() Join Date: May 2004
It sounds like you have an Eaton Rear. I also have a '69 3/4 ton. I believe the ratios are either 4.11 or 4.57...
Chris |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
It could also be a eaton from the round cover you describe..
Jim it does not look like any of them, dana or gm the filler hole is on the left hand side of the cover.when you are standing in the back of the truck.
T T T.
Cantankerous Geezer
Try this website to i.d. your differential.
Differential Applications
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Geared for Collision
heres my eaton
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB 1970 C/K20 3/4 Ton 1996 Collectors Edition Corvette 1977 Corvette Coupe |
thank,s budweis
4.10 or 4.56 most likely. Ratio not on the case. You can either pull the back cover to read it or do the old spin the wheel and watch the driveshaft routine.
Broke
Dang Budweis that looks good! Do you have anymore pic's?
72CheyenneSuper1ton4x4BigBlock |
#13 | |
#14 |
Budweis,
I Assume Your Truck Was Originally Drums All Around. Where Did The Discs Come From? Is There A Manufacturer Producing A Conversion Kit To Go To All Drums? Thanks
69 chevy 1/2 ton 2wd 72 GMC 1/2 ton 2wd |
#15 |
yeah was 4 wheel drum, got the rear disc kit for the eaton at Blackbirds and for the front im using a 72 dana 44 with disc already on it i got from bram. all 4 wheels will use the same rotor calipers, and pads now which is also a bonus.
#16 | |
![]() Thanks Budweis
Support The Board |
#17 |
Broke
WOW! That looks really good. What size are those slicks
#18 |
thanks bram, tires are 35x14.50 on 16x10 rims. it's getting a 6" lift.
#19 |
![]() Join Date: May 2001
Here is a pic of where the #'s are stamped on an Eaton rear end. Not a very good pic, but it should help. If you find the letters, I can look it up for you.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
#20 |
Opps, forgot the pic,
#21 |
That pic is the top of the 3rd member. Good luck!!
#22 |
:p Joe the # on the rearend are MU0110G there is another # lower on the drivers side also 3883379 all help is apreciated biglou.
#23 |
My book shows 1969 "MU" to be a 3:73 Locking axle for a C-20 or a
G-20? It also shows "MU" to be a 1967 C-30 5:14 Locker rear axle? Does that sound like what you have???
#24 |
Joe i beleive it,s the mu 3-73 unit the rear hasn,t been changed acording to the p-o . is it worth anything seeing that it is a 3/4 ton locker. biglou 55 (
#25 |
If your rear axle is a Eaton, I have never seen a 3:73 ratio in one of them. You might want to double check by pulling the cover and getting the numbers off the ring gear. You might also double check the "MU" code on the rear end again. My book shows codes for trucks and vans, and I am thinking the 3:73 was a van ratio??? Having the locker makes it worth alot more.
