Old 08-09-2004, 01:52 PM   #1
GarageGhoul
question for all you guys with air bags
Hey all you guys with air bags, who here has a good set up that they put together the cheapest? any body go with manual fill? If so how much?
63 c-10 shortbed fleetside
GarageGhoul is offline   Reply With Quote
Old 08-09-2004, 05:20 PM   #2
SCOTI
SCOTI's Avatar
Read up . . .....
http://67-72chevytrucks.com/vboard/s....php3?t=108211
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-09-2004, 08:23 PM   #3
XXL
Seņor Member
XXL's Avatar
Originally Posted by SCOTI
But it's easier to just ask the same questions over and over than to use the search function
XXL is offline   Reply With Quote
Old 08-10-2004, 07:41 AM   #4
Woogeroo
Hey GarageGhoul is a new guy and this website is his first forum - he may not even know about searching old posts yet.
I know I'm not entirely sure how to search the forums here at 67-72trucks.
-W
Woogeroo is offline   Reply With Quote
Old 08-10-2004, 10:04 AM   #5
SCOTI
SCOTI's Avatar
True... the current set-up does not promote the use of searchs. But, it's pretty easy to sit back & read thru @ least the last month worth of posts in each forum to check threads w/similar content.
I'm no web veteran, but of the boards I do frequent, when I was new I would lurk around & read as much as possible before asking questions because alot of people are sensitive to repetitive questions.
Glad to have new guys around.... welcome to the board.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-10-2004, 11:04 AM   #6
Putter
More Cowbell....
Putter's Avatar
Our search function seems to be MIA anyway.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 08-10-2004, 04:36 PM   #7
GarageGhoul
Actualy I have used the search and read all the results, Ive tried to use it recently and it's not working. ]AND I have read through almost all the suspension threads on here but I still had some questions. You know with sarcastic remarks such as the one made by XXL, I almost want to go back to just lurking. Finaly got the guts to post and this is the response I get? Do yo consider that helpfull? by the way thank you Woogeroo and SCOTI. I have read up alot more than some people suspect and SCOTI, your threads have been very helpful in the past.
Old 08-10-2004, 04:51 PM   #8
SCOTI
SCOTI's Avatar
Glad to be of assistance. Don't let the short fuse of some alienate back to lurking. XXl does come across bitter @ times but does offer alot to the board as well & I welcome him too.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-11-2004, 05:36 AM   #9
Woogeroo
Ok - no searchy action. I thought maybe I was going nuts.
-W
Old 08-11-2004, 02:12 PM   #10
XXL
Seņor Member
XXL's Avatar
I see the fine line between the sarcasm you describe above (mean spirited) and the lighthearted quip I posted has been blurred again. Out here on the Intarweb, we sure wear all our sensitivities on our sleeves. Lighten up, people.
