Mudslides 'r my specialty
Doetsch Tech Nitro Slammers
Doetsch Tech Nitro Slammer Shocks (two 4052's and two 4095's)
$100 plus shipping (fronts were installed for a very short time (maybe 30 miles on them)) (the rears are brand new, never installed) Please post here before you PM so that it stays in order this time. Thanks, Brandon Again, I travel with work, so if I don't get back to you right away, please be patient.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 Last edited by 8t5Silverado; 09-07-2004 at 01:02 PM. |
how much drop are these designed for?
I think they work for a 3/5 or 4/6. I was doing a 4/5 (really 4/6 with my spring sag) with Western Chassis shock extenders.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
to the top
It followed me home?
Will you sell just the rear? if so how much shipped to 80134
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Sorry Adam,
I lost track of this thread.
are the 4 shocks sold yet?
Ground Pounder
shocks
do you have to have the shock extenders to use the rear shocks if so where did you get them from nd do you have a part # thanks
Garage Queen Material
i'm interested
#10 | |
1.5-2" 3-4" 4052G 4163G 2.5-4" 5" 4809G 4095G 4" 6" 4052G 4095G 5-6.5" 7" 4809G 4095G 4052-front 4095-rear(i havent seen a 4093) the fronts should be good up to 4" drop in the front. but that is only counting drop springs, since the spindles just move the wheel position. and the rears are good for a 5", 6", or 7" drop in the rear |
I still have the 4 shocks.
Sorry, I am travelling with work and can't check the board everyday. I got the shock extenders (they're gone now) from macspring, but I don't know the part number. What Eric said is true. The drop created using a drop spindle does not affect the shock length at all, since it does not alter the geometry of the a-arms. When you use a drop coil spring or a spindle with a drop coil spring, then a shorter shock is necessary. I got a PM wanting these, so that is pending right now.
| Bookmarks |
