Old 08-09-2004, 08:26 PM   #1
thorchar
frame welding
can you weld a rusted out frame with an eletic welder and what size steel and rods its rusted out in front of the right rear spring
thorchar is offline   Reply With Quote
Old 08-09-2004, 11:03 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes, you can weld a frame.
But, honestly, if you had to ask that question, you'd better get someone more experienced at welding to do it.
If the frame needs repair because of rust damage, I'd replace it with a better one. There is no Chevy truck anywhere that has a frame that's very rare or hard to get. Just look around, there are better frames out there that don't need major rust repair.
Old 08-10-2004, 05:06 PM   #3
smokekiki
Mike
smokekiki's Avatar
Chances are,once You get to poking around,You will find other places that are bad on the frame.It's not a place to learn welding.What truck is it and what are Your plans for it?
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 08-10-2004, 06:17 PM   #4
78chevstepside
78chevstepside's Avatar
I would find a good frame at a junkyard and cut that section out( extra long). Make a temporary support to hold the frame in place. Stick welding works great for dirty contaminated metal. I would use 6010 for the root and cover with low-hy 7018 . I would cut the rusted area out. Make a cardboard template. Tranfer the template to the new frame then cut it out. Weld finger bars to hold the new part in position. Weld in new part. Piece of cake .
78chevstepside is offline   Reply With Quote
Old 08-10-2004, 07:08 PM   #5
1972C10
1972C10's Avatar
Good rods for suggestion but He might not have a dc arc welder You can get an AC7018 But they dont make a 6010 +++ that i know of in ac conifg so you might want to try a 6011 not quite as good as a 6010 but for that purpose should be fine espically when capped with a 7018
1972C10 is offline   Reply With Quote
Old 08-11-2004, 08:10 PM   #6
crazy longhorn
Fabricate till you "puke"
I have to agree with Tx Firefighter on this one.....you can repair the frame, but it should be pretty cheap to replace(depending on your area). i have done a little stick welding in my time....cut a couple trucks in half, & "glued" them back together(big job). i also like to run a 6011 rod on the rusty stuff, altho, i will say that a sandblasted /prepped area would be much more fun to work on......buzz it with the mig. that old ac stick welder has seen some time, but finally moved over for a 200 amp lincoln mig(that baby "rocks"! ) crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
