Old 08-09-2004, 10:28 PM   #1
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Gear Drive
Has anybody here ever used the gear driven timing other than a timing chain? What were your results / experiences with them?
Todd
toddtheodd is offline   Reply With Quote
Old 08-10-2004, 12:04 AM   #2
Ogier
Chopper/Painter
Ogier's Avatar
Yes, Many times.
Keep your HP under 450 and you will be fine. I have only had failures in the post 450Hp range.
Ogier
Ogier is offline   Reply With Quote
Old 08-10-2004, 08:14 PM   #3
chevyboy55
chevyboy55's Avatar
Gear drives
I had a Pete Jackson in a 71 El Camino & never had a problem with it.
chevyboy55 is offline   Reply With Quote
Old 08-10-2004, 08:35 PM   #4
frogsmakr
frogsmakr's Avatar
gear drives are noisy, but don't stretch
frogsmakr is offline   Reply With Quote
Old 08-10-2004, 08:51 PM   #5
mocwon
Keep On Truckin'
mocwon's Avatar
I bought a nice used Pete Jackson "quiet" set for a 350 I am building only to find out I can't use it since the engine is fuel injected and has a knock sensor. Apparently, the sound of the gears affects the computer when the knock sensor picks up the noise. If you are interested, I will sell you the set for $75 shipped to your door. They are about $150 new.
Todd
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 08-10-2004, 10:08 PM   #6
Shane65
I"ve been running an Edelbrock gear drive(slightly noisy but not as loud as the Pete Jackson ones) for the last 6 years. The engine is fuel injected and has a knock sensor. I can read what the knock sensor is doing with my laptop and there is no issue with the gear drive sending readings to the emc.
Shane65 is offline   Reply With Quote
Old 08-10-2004, 10:44 PM   #7
mocwon
Keep On Truckin'
mocwon's Avatar
Interesting.... I wonder if the Pete Jackson set up is just too noisey as opposed to the Edelbrock setup?
Just Passin' Thru
