08-10-2004, 01:53 AM | #1 |
Professional Grade
Battery relocation
Hey guys! I'm gonna need to relocate my battery to the other side of my rad, what all would I need to do as much? Just a longer positive battery cable and a driver's side battery try from a dual battery truck?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
08-10-2004, 09:11 AM | #2 |
Yep that's basicly it. Get as fat of a cable as you can.
Dealer was able to still get the driverside batery bracket and the battery tray (the tray is same left right bracket is the different part). They got me $12 for the tray and I thing the bracket was like $15.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
08-11-2004, 11:15 PM | #3 |
I'm making a battery box, and mig welding it to the inside of the frame under the cab. It'll be away from exhaust, and will be a pair of sealed optima batteries. I'm gonna have a couple of heavy bungee bands holding them in place. The main reason for this, other than moving the weight back, is to have a central location for the starter/electrical system power, as well as the 2 1000w sony amps under the bench seat. I currently use 4ga instead of 6ga to the starter, and it spins like a turbine when I hit the key. also, 4 ga will handle the max 2000w, whereas 6ga handles about 1000w. I'm using 16ga, and will drill some holes in the back to help with the mig welding to the frame. then just unfasten a couple of bolts, and the old battery tray and support bracket are history.
08-11-2004, 11:19 PM | #4 |
Stepsides RULE
lol my battery is being held in place by a belt. not an automotive belt, a wear-around-your-jeans belt. the battery tray is like almost non existent; but don't worry im ordering a new tray and everything like next week or sooner since my battery is acting like it is time...
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
08-12-2004, 12:00 AM | #5 | |
08-12-2004, 03:14 AM | #6 |
driving is in my blood
In my black truck I used a nice hold down bar for the battery....I had two batterys end up upside down, empty and dead. I have one bungee cord on the battery in the 79, its given me years of not one single problem. You call it a hack job, I call it somthing that works.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
08-12-2004, 08:14 AM | #7 |
ROCKET POWER!
You can get get a good frame mount battery tray from 1997 or newer vans with diesels (or any van with dual battery RPO). It mounts to the side of the frame with 4 bolts. Earlier model Vans had a frame mount battery option but it's not as easy to adapt.
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
08-12-2004, 11:08 AM | #8 | |
My 4x4 club will not let you ride with them if tha battery is like that. We require the battery be bolted down like facotr or better. Why? cause more then once we have had to patch radiators back together 2-3 miles of hard trail into the woods. One time the battery ended up upside down on the frame and welded itself there and caught fire. That was when the rule was made. It doesn't take a lot of effort do get a good battery tray BOLTED in. They are readily available in universal form at most parts stores. It's a lot cheaper then a radiator or a truck.
08-14-2004, 11:38 PM | #9 | |
08-14-2004, 11:40 PM | #10 |
He'd be a lot better off getting a battery box, bolting or welding(if metal) to the front pass corner of the bed by the bulkhead. that space is hardly used anyway (at least by me). my .02
08-14-2004, 11:52 PM | #11 |
i just bought a cheap black plastic box from wallmart, used the suplied mounting hardwere, and used 1/0 ga wire from home depo as well as some rubber inserts to put in the holes in the bed, dad got some crimp on 1/0 ga lugs for the started and i heat shricked it as well, i got a cheap-o bolt on to the end of the wire type clamb for the battery end of the wire and heatshrinked that end too, my truck came with a 2 ga wire and that had a hard time of turning the starter on my 454 due to voltage drop across the wire, i got a 1/0 battery cable from tractor suply or auto zone has them, that worked, but i got tired of having my battery tied down with a pice of string and a tauntline hitch(im an eagle scout so i know knots) its been working great, xpt im afraid of some idiots stealing my battery at school, its not NHRA certified cause the battery would need to a suport system welded to the bed, but i have an IHRA track here so im not to worried about it, for any battery cable i would use 1/0 wire or maybe even 2/0 if you were moving it all the way to the bed, i wish that i did use 2/0, but i didn't think to at the time,
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
08-15-2004, 09:51 PM | #12 |
LED King
Why do you want to relocate it? The only reason I can think of is so that the positive battery yerminal isn't so close to the core support. If that is your only reason, they have reverse polarity batteries.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
08-15-2004, 10:28 PM | #13 |
Professional Grade
My TPI air cleaner will sit pretty much right where the battery tray is right now, so I gotta move it to the Driver's side.
