Old 08-10-2004, 07:52 AM   #1
Jimbotronics
YA YA
Jimbotronics's Avatar
Need help - What size carb to go with?
I currently have a 2bbl carb set up on my 71 350, it runs out nicely but seems to be sluggish on take off - I want to change the carb over to a 4bbl setup for better power/throttle response but not sure what size to go with. I want the truck to have nice throttle response and haul ass but I'm not trying to build a racer. I'm thinking a 600 to 650CFM. Gimmi some opinions please.
Jimbotronics is offline   Reply With Quote
Old 08-10-2004, 07:57 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
600 cfm and make sure it has vacuum secondaries.
Old 08-10-2004, 08:06 AM   #3
Jimbotronics
YA YA
Thanks! Also, the current carb is a manual choke - what's involved in changing it over to an electric and should I change it or just leave it manual?
Old 08-10-2004, 08:08 AM   #4
Jimbotronics
YA YA
I would assume that it just needs power that's controlled by the eginition switch.
Old 08-10-2004, 08:30 AM   #5
67chevemall
67chevemall's Avatar
Manual Chokes are great just leave it!
Then you control the helm!
Cheers
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 08-10-2004, 11:47 AM   #6
Tx Firefighter
I only do electric chokes myself. A switched power wire is all it takes.
By the way, when I said vacuum secondary, lots of folks think only of Holley, but all Carter, Edelbrock, and Rochester 4 bbl are vacuum secondary.
Old 08-10-2004, 02:00 PM   #7
cdowns
cdowns's Avatar
sounds more like a timing/tuneup issue you have .
Old 08-10-2004, 02:41 PM   #8
Jimbotronics
YA YA
Figured that mostly likely had a lot to do with it as well - I'll be changing the wires, plugs, cap, and rotor this weekend. I know what the timing is but don't have a timing light or know how to use one if I had one. Hopefully one of the guys I work with can help me out on that one. Anything I need to change besides what I mentioned?
Old 08-10-2004, 03:45 PM   #9
cdowns
cdowns's Avatar
if you still have the original distributor you should change the points and condensor
and changing to a 4barrell usually means changing the manifold and to do that requires removing and reinstalling the distributor. a timing light and dwellmeter is pretty much required
Old 08-10-2004, 06:08 PM   #10
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Edelbrock Performer and Edelbrock Q-Jet. It's what I have and I like it.
Member Nr. 2770
