Old 08-10-2004, 01:09 PM   #1
67chevytodd
Junior Member
72' doors
I found a 72' short wheel base step side that has been rolled. The truck has low miles and I would like to rebuild it. I think I can just weld a different top on the cab, but my problem is with the doors. What is the difference between the 1972 doors vs. 67-71 doors? I have 2 sets of the 67-71 doors, what would have to be done to them to use them on the 72' cab? -- Or whould I be better off finding 72' doors? Thanks for the help, Todd
Old Chevys never die they are just reborn!
67chevytodd is offline   Reply With Quote
Old 08-10-2004, 01:15 PM   #2
71swb4x4
71swb4x4's Avatar
67-72 doors will work in the 72. The only exterior difference is the screw in door, on the upper part of the main area of the door.
Internally I think there may be a difference in the way the window regulator bolts up, but I am not sure.
If you use the other doors with all of their internals you will have no problems.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-10-2004, 02:33 PM   #3
Mixup
The 72 regulator has a longer shaft because if the thicker door panel.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 08-10-2004, 11:39 PM   #4
ZOOMY
stepside
I think you should just sell it to me.........Zoomy
ZOOMY is offline   Reply With Quote
