I noticed when I was cleaning the engine compartment that the plug for the Blower resistor on the evaporator box got Hot. The Dark blue wire has some brown discoloration to it right were it goes into the plug itself. With the blower running the plug & resistor portion gets real Hot. I checked the fuse & it had a 25amp I think it calls for a 20. I stuck a 15 in it until I can get to the parts store. It still gets really Hot. I'm going to have to replace the plug, the plastic got to Hot & broke off showing the terminals. Is the resistor bad?
Troy 1982 Silverado |
Anyone have any clues? Is maybe the Blower motor bad?
LED King
That is how the resistor lower voltage - it turns it into heat. Some heat is perfectly normal. Melting things is not. When it gets that hot it needs to be replaced.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
blower motor bad. when not working right, draws too many amps to run, wires get hot. could be bad brushes, whatever. replace motor, resistor too, and any toasted wires, you'll be fine..
