Old 08-10-2004, 03:47 PM   #1
FormerMember
Power Steering conversion
What all is needed for a 72 C30 with manual steering?
I have the box and pitman arm from a 76 C30
FormerMember is offline   Reply With Quote
Old 08-10-2004, 04:54 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
get you a power steering pump with pulley and brackets, the two hoses, and a belt.
Old 08-10-2004, 04:59 PM   #3
FormerMember
Cool, got those on the 488 going into the truck...
How about steering linkages? Will they bolt on?
I see the catalogs call for a different adjusting sleeve for PS?
Old 08-10-2004, 05:06 PM   #4
Tx Firefighter
No linkage issues at all. The only difference is the pitman arm, which you already have the p/s one, so you're set.
Old 08-10-2004, 05:07 PM   #5
FormerMember
Great. Easier than my Blazer was...
Old 08-10-2004, 08:49 PM   #6
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
So when I'm hunting this weekend, what years should I look to get the steering box and pitman arm from? I guess the newer the better, but where's the cutoff year?
Guess I should look for the fitting for the rear of the pump, too, so I can screw it into my serpentine-setup PS pump, like Tx Firefighter recommends, so I won't need custom hoses.
Thanks...SSOW
69 C10 (#1 son's ride)
72 C20 (Dad's farm truck)
82 K30 (Ex - brush pumper project)
stickshift_or_walk is offline   Reply With Quote
Old 08-10-2004, 08:53 PM   #7
69 Short Fleet
Don't forget a double groove crank pulley.
69 Short Fleet is offline   Reply With Quote
Old 08-10-2004, 08:59 PM   #8
stickshift_or_walk
Oh yeah, and what tools to take to get the pitman arm loose from the ... what is it ... drag link?
SSOW...showing my ignorance
Old 08-10-2004, 09:40 PM   #9
flatblackclassic
You need a pickle fork and a BFH (Big Freakin hammer) I have a pickle fork that goes in an air hammer and makes the job real easy.
flatblackclassic is offline   Reply With Quote
Old 08-11-2004, 10:33 AM   #10
FormerMember
Or a 2-3 jaw puller that requires no hammer to slam into steering components...
Old 08-11-2004, 11:57 AM   #11
stickshift_or_walk
That sounds better. I may go ahead and buy a puller. Lots of times it would be handy.
So what about the below question, which years will fit?
Thanks...SSOW
Old 08-11-2004, 12:14 PM   #12
FormerMember
Thanks...SSOW
Any will work, it depends on what lines you're running. Compression fitting or O-ring.
I'd grab the whole shebang, which is what I did.
When I looked at it last night, everything was pretty obvious.
Old 08-11-2004, 12:36 PM   #13
stickshift_or_walk
I got the pump and serpentine setup from an '89 C1500 350V8. Do you think that box will work? I didn't know when I was there, so I left it on the truck. I did take the lines - i think they are compression.
Thanks...SSOW
Old 08-11-2004, 12:54 PM   #14
FormerMember
Thanks...SSOW
That should be o-ring, if my memory serves correctly.
That box should work. I am not sure about the pitman arm though. The earlier 2wd PS pitman arms should work on that box though.
Old 08-12-2004, 11:10 AM   #15
stickshift_or_walk
Will it fit?
Yep, I checked it last night, and it's the o-ring type.
Has anyone done this? A PS gearbox (and matching pump, etc.) from an '89 C1500 to replace the manual box on a '69 C10? Sounds like the box will bolt up (although other threads suggest possible line routing problems), but what pitman arm will I need?
Thanks...SSOW
Old 08-12-2004, 12:25 PM   #16
FormerMember
It's not rocket science :p
Check the hole sizes. If the late model stuff is wrong, you can either have it reamed (hole is too small) or buy one for your year truck with PS. Could also looking into swapping ends, but I am willing to bet a cup of Army cawfee that it will bolt up.
CW02 Grendel
