Old 08-10-2004, 04:27 PM   #1
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
vacuum gauge
I know that the stock line was metal, is there any way I can go from metal on the back of the cluster with a clamp to a rubber hose that goes to the carb? Will that provide accurate readings?
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 08-10-2004, 04:52 PM   #2
junkyardjohn
junkyardjohn's Avatar
I'VE HAD A RUBBER LINE ON MY FACTORY VAC. GAGE TO MY CARB. FOR 8 YEARS. IT SEEMS TO WORK O-K. IT SEEMS LIKE I USED FUEL INJECTION FUEL LINE , OR SOME GOOD TYPE FUEL LINE INSTEAD OF REGULAR VAC, HOSE. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 08-10-2004, 05:08 PM   #3
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Thanks alot for the help! I figured it'd work that way... Just wanted to be sure.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 08-10-2004, 06:21 PM   #4
Gee_Emm
I use a rubber line on mine, I took the gauge to a auto parts place and found a fitting that screwed on that had a barb type hose connector on the other end, then I just slid the hose onto that.
Gee_Emm is offline   Reply With Quote
