Old 08-10-2004, 05:18 PM   #1
moodyholler
moodyholler's Avatar
FYI 1979 rear cclip axle will fit a 1972.
I got an axle from a 1979 blazer yesterdasy and put it in. It fit fine. moodyholler
1998 WRANGLER I-6 auto
1972 LWB FLEETSIDE
1968 GMC SWB STEPSIDE
1994 C-1500 SWB 4.3 5 SPD
moodyholler is offline   Reply With Quote
Old 08-11-2004, 01:45 PM   #2
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Doesn't the '79 have staggered rear shocks and the '72 have non-staggered rear shocks? How did you bolt your shocks up?
badpeanut is offline   Reply With Quote
Old 08-11-2004, 05:10 PM   #3
moodyholler
Peanut
I used the axle itself, not the housing. No one would/could tell me whether or not it would work. So I tried it out and viola, I'm up and running again.moodyholler
1972 LWB FLEETSIDE
Old 08-11-2004, 07:37 PM   #4
badpeanut
badpeanut's Avatar
moodyholler, is your Blazer a 4x4?
If so, that is great news as my '71 K5 needs axles and I have some later ones.
Old 08-11-2004, 08:13 PM   #5
moodyholler
Yeah it is a 4x4.
I asked around and could get no answer so I threw one in. moodyholler
1972 LWB FLEETSIDE
Old 08-11-2004, 08:17 PM   #6
moodyholler
Moser axles are 264.00 to your door.
This price is for a pair. I have been fighting a bent axle for a year. I have replaced both driveshafts, four wheels and tires,axle bearings and seals. Hub of axle showed no runout, however, axle was bent about six inches from hub. Didn't find it until I took it out as I was going to start replacing bearings on carrier and pinion. Just my luck. Should drive a lot better. moodyholler
1972 LWB FLEETSIDE
