Old 08-10-2004, 06:33 PM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
2 holleys for trade w/ pics
Ones a square bore the other a spread bore. Both have electric choke, vac. sec. The spread bore was purchased by my neighbor for a problem that ended up not being carb related, he gave me the carb when he moved. The square bore was on a 305 in a 82 C20 you can see the adapter.
I'd like to trade these for a H052 locker with or with out the gears.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-11-2004, 10:55 PM   #2
FRANKIEPOTATAS
let me know if you want to sell that spreadbore
FRANKIEPOTATAS is offline   Reply With Quote
Old 08-30-2004, 02:02 PM   #3
72ChevyRock
Which is the square bore, the clean one or the dirty one? I have a 307 with a two-barrel and would like to upgrade to the 4-barrel. I would like to do this without changing the manifold if the adapter would fit the 307. As you can tell, I'm not too smart when it comes to carbs. I am learning as I go.
72ChevyRock is offline   Reply With Quote
Old 08-30-2004, 03:15 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The dirty one is the square bore, the adapter goes between a 4 barrel spread bore and 4 barrel square bore. I guess I need to come up with some prices. Sure would like a locker for my H052, though.
