Old 08-10-2004, 07:06 PM   #1
ocbaud
Garage Queen Material
would this fit?
gears and govlock unit from an 8.5" rearend from an 88-up truck?
ocbaud is offline   Reply With Quote
Old 08-10-2004, 07:29 PM   #2
Russell
Professional Grade
Russell's Avatar
88-up trucks have a much wider frame than our 73-87 trucks do, I'm sure it could be done, but may be more effort than you wanna put in...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 08-10-2004, 07:31 PM   #3
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
I would highly recommend staying away from the gov-lok, they don't do to good in performance applications.
NeCrOmAnCeR is offline   Reply With Quote
Old 08-10-2004, 07:55 PM   #4
ocbaud
what if i got a set of relativly new richmond 3.73 gears and goclock with only 30k miles on it for $200?
Old 08-10-2004, 09:16 PM   #5
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
It would be difficult to set up those gears to be the same as they were in the newer housing back into your housing. Also, the 88 and up rears use 31 spline axles instead of 28 like the 79-87 10 bolts.
You'd be better off buying a new set of gears and a new posi so you only have to pay to get it set up once.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 08-10-2004, 10:11 PM   #6
ocbaud
thats what i needed to know thanks
