Old 08-10-2004, 07:29 PM   #1
Steve @ BROTHERS
Air Cleaner Stove Pipe / Heat Riser question
Our '70 4x4 was very original when we got it. One owner and only 55,000 miles, but it did have headers. Now we're putting it back together with manifolds and trying to determine if it was supposed to have a "Stove Pipe"? From the looks of the air cleaner, it DID have one from the factory. The air cleaner has the large open fitting on the bottom of the snorkle for a pipe. Does anyone have pictures of the small block stove pipe setup? Does anyone have a stove pipe setup for sale? Could use any help I can get with this one too. Current pics of the truck are below:
Steve Flanders
BROTHERS
Toll Free 800-977-2767
Local Phone 951-808-9790
Email Steve@BrothersTrucks.com
Steve @ BROTHERS is offline   Reply With Quote
Old 08-10-2004, 07:53 PM   #2
racedvl
racedvl's Avatar
Is that the bad boy that the center link I got you is for?!? Man 'o' man that truck is gonna be sharp!!
racedvl is offline   Reply With Quote
Old 08-10-2004, 07:58 PM   #3
Steve @ BROTHERS
Indeed it is !!!
Hey, Thanks again for going out of your way to get me that centerlink. It's at the powder coater now, hopefully it won't get lost like the last one.
Steve Flanders
BROTHERS
Old 08-10-2004, 09:16 PM   #4
Southpa
Southpa's Avatar
Here is my stovepipe setup, sorry! its not for sale. You will need the pipe and 2 piece (I think) collector that fits around the exhaust manifold. I might be looking for a new collector myself as mine is beginning to crumble. But they sure do work on those cold mornings!
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 08-10-2004, 09:26 PM   #5
nu2-72
Steve, awesome truck.
What is the best technical source for the correct procedure on restoration of these trucks?
I would like to know the step by step. Also how did you prep and finish your axles?
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 08-10-2004, 10:06 PM   #6
racedvl
racedvl's Avatar
Originally Posted by Steve @ BROTHERS
Indeed it is !!!
I'm just glad it was the one you needed!
Old 08-11-2004, 12:59 AM   #7
A few 72's
A few 72's's Avatar
Here's a link to one on ebay that Gee Emm posted.
Has a little more than you are looking for, but does not have the piece that fits around the exhaust manifold.
http://cgi.ebay.com/ebaymotors/ws/eB...category=10076
A few 72's is offline   Reply With Quote
Old 08-11-2004, 02:53 AM   #8
Jemost 72
Southern Bowties
Jemost 72's Avatar
The 'base' plate mounts between the engine and ramhorn. The outer part that surrounds the ramhorn is mounted to the base plate with small screws. The lower end of the hot air pipe is attached to the top hole of the outer surround part with 2 screws. The top end of the hot air pipe goes into the snorkle.
1972 Cheyenne 350/350
Jemost 72 is offline   Reply With Quote
Old 08-11-2004, 07:13 AM   #9
mrein3
mrein3's Avatar
Two things:
I have my engine out and just detailed the pieces you want to see. The outside piece I painted with Eastwoods factory gray exhaust paint. The inside piece appears to be aluminum so I left it alone. I'll snap some shots tonight.
The other thing I'd like to point out is that you have a rams horn style exhaust manifold on the LHS of the engine with the angle back dump. I'm pretty sure that all 4x4s had the rams horn style manifold that dumps straight down the middle. BOTH the manifolds I took off my working engine when I pulled it had a part number and "RH" in the casting. I'll take shots of them too for you.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 08-11-2004, 11:11 AM   #10
Steve @ BROTHERS
Originally Posted by mrein3
Two things:
Man having those pictures of everyones Stove Pipes is really helpfull, thanks, keep 'em coming. As far as the angled dump on my LH manifold.... I had a straight dump on there first but took it off because it was way to tight against the enginge mount. After asking around a bit, it seemed nobody has a real clear answer on whether or not a 4x4 should have a straight or angled manifold, so I opted for the one that gave me some clearance. Since we're trying to do a spot on resto on this truck, I'm willing to change it if somebody can provide a reasonable amount of proof that it's supposed to be one-way-or-the-other.
Steve Flanders
BROTHERS
Old 08-11-2004, 11:29 AM   #11
Steve @ BROTHERS
nu2-72,
The factory shop manual and assembly manual are real good resources when you're doing a restoration on your truck. This board is an awesome resource too. I wish there was a real good book written specifically for trucks with info on details like proper colors for components etc, but there's not. There are great books for Camaro, Chevelle, Corvette and such that are good on detail stuff, and most of the info correlates with trucks too. I've used them plenty of times to figure something out. One thing I do is take pictures and notes during disassembly so that I can use them to put things back the way they were when it comes time to reassemble. Take good pics of little things like clip colors & locations, hard lines & hose routing, wire routing and what types of fasteners are used. Any of the details you think will be important when you put it back together. I always try to determine the original color of components too. Make notes so you can put them back the way they're meant to be.
That's some of what I do. I'm sure there's plenty of ideas floating around this board also. Like I said, this is an awesome resource right here.
Steve Flanders
BROTHERS
Old 08-11-2004, 03:10 PM   #12
pickupman
pickupman's Avatar
Steve, as far as I can tell, I have nothing in writing, just experience. All 4wd's were striaght down dump on both sides. I have parted many and had alot of 4wds. Also if you go back to the straight down, the stove is a little different on the bottom on the straight dumps. I don't believe I have any right now I will double check. I may have the pipe.
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 08-11-2004, 03:28 PM   #13
Steve @ BROTHERS
Experience works for me Let me or JC know if you have anything
Steve Flanders
BROTHERS
Old 08-11-2004, 04:33 PM   #14
sactoC10
71 DELUX
sactoC10's Avatar
pipe
Steve,
I have a pipe, but not the stove part that surrounds the manifold. I am sure that you probably already have the air cleaner assembly... so I am not sure if what I have would be worth your time.
I was not going to sell it, but maybe we could work out some sort of trade if you've not found anything yet? Let me know, I always need something! I'd rather swap for a part anyway!
I'll check my stash of parts to see if maybe I have the stove assembly.
Jeff
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50
2003 FORD Escape
1998 Honda VTR1000
sactoC10 is offline   Reply With Quote
Old 08-11-2004, 06:25 PM   #15
pickupman
pickupman's Avatar
Steve, I will check when I get home tonight or in the morning, and give you a call tomorrow. I have been thinking and I may have it all if it is still there.
Old 08-11-2004, 07:28 PM   #16
Steve @ BROTHERS
Bill,
I'll keep my fingers crossed that you have an entire setup. Just let me or JC know. From the sounds of it, I'm gonna need a LHS exhaust manifold too. Can't use the one I have here because it has an alternator bracket cast into it.
I'll wait to hear back from you, Thanks.
Steve Flanders
BROTHERS
Old 08-11-2004, 08:08 PM   #17
mrein3
mrein3's Avatar
Here are the pictures of the stove pipe I promised. Since my engine guy is a month late I have had lots of time to paint things.
'72 Malibu hard top
Center City, MN
Old 08-11-2004, 08:11 PM   #18
mrein3
mrein3's Avatar
OK. I'll try it again...
'72 Malibu hard top
Center City, MN
Old 08-11-2004, 08:16 PM   #19
mrein3
mrein3's Avatar
Here are my exhaust manifolds. This truck was NOT stock when I got it. However one of the parts house catalogs I looked at indicated the LH and RH manifolds are the same. Mine appear to be the same but one has a "61" and one has a "62" in the casting. The part numbers and the "RH" cast in appear to be the same.
Another data point. I ordered the LMC dual exhaust kit a couple of years ago. It bolted up to my "stock" manifolds with NO monkey business.
'72 Malibu hard top
Center City, MN
Old 08-11-2004, 09:22 PM   #20
Steve @ BROTHERS
Perfect pictures and info, thanks mrein3.
Steve Flanders
BROTHERS
Old 08-11-2004, 09:54 PM   #21
pound41
The straight dump manifolds are there because on the passenger side the exhaust has to travel between the transfer case and the frame a tight hole- would take some bending without the straight dump
pound41 is offline   Reply With Quote
Old 08-12-2004, 07:17 AM   #22
mrein3
mrein3's Avatar
No Steve, thank you. I saved those close ups of the engine at the top of this thread. If I ever finish this engine project I have accumulated all the parts to give my truck AC. I modified the firewall last fall. I collected all the stock brackets but wasn't quite sure how they all bolted together. Now it is easy to see.
Thanks again. This board is the best!
Matt
'72 Malibu hard top
Center City, MN
Old 08-12-2004, 01:58 PM   #23
pickupman
pickupman's Avatar
Steve, here is some pictures of the only one I have. Someone had put a piece of flex pipe on it and that would need some attention. I don't think it would be that big of a deal to fix. The rest of the stove and manifold and pipe are in good condition. If interested let me know.
Old 08-12-2004, 10:37 PM   #24
mrein3
mrein3's Avatar
One more picture if you're still paying attention to this thread.
This was taken before I started pulling stuff. It isn't real clear but it shows the heat exchanger deal installed and also shows how close the center dump rams horn come to the engine mount.
I left it large...
...I hope the file size is small enough.
It is hard to believe those are the same parts pictured above before I applied a little elbow grease and paint.
'72 Malibu hard top
Center City, MN
Old 08-12-2004, 11:35 PM   #25
Steve @ BROTHERS
Thanks to everyone here for the info, pictures and parts. I've managed to locate all the parts necessary to put the Exhaust Manifold and Stove Pipe assy together. Thanks to those of you who have offered or are sending parts for this project.
I will be sure to post pictures of the Stove Pipe assy here once we have it together. More pics of the truck to come also as progress continues.
Actually, I'm going to need a set of spark plug heat shields too, contact me if anyone has a spare set.
Steve Flanders
BROTHERS
