Old 08-10-2004, 09:27 PM   #1
Hook'em
Hook'em's Avatar
Gauges
My temp. gauge is not working. It appears that the wire going to the sensor got too close to the manifold. I first plan to replace and re-route the wire, but if that doesn't work, I will probably have to replace the gauge.
Can the temp. gauge be replaced by itself, or does it require changing the entire cluster?
Hook'em
Hook'em is offline   Reply With Quote
Old 08-10-2004, 09:34 PM   #2
whitesswj
Embrace the Redneck
whitesswj's Avatar
you can replace the guage itself w/out replacing the cluster
sswj, i think i might have one ..... i don't know if it or they work or not
sswj
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
Old 08-10-2004, 09:35 PM   #3
A.P.
Black 72 Chevy
A.P.'s Avatar
Guage it selft can be replaced.
A.P. is offline   Reply With Quote
Old 08-11-2004, 04:47 PM   #4
Hook'em
Hook'em's Avatar
Thanks for the information. I still hope I can fix it without changing out the gauge, but we will see.
Hook'em
Old 08-11-2004, 05:00 PM   #5
Old Dave
Is a bullfrog waterproof?
Old Dave's Avatar
Those gauges are usually pretty forgiving. The wire on my 86 Suburban did the same thing after the engine was rebuilt (not by me). I just cut out the burned part, soldered in a new wire with heat shrink and it worked fine. There is a web site where you could buy the new shunt to go on these gauges and a lot of other gauges for other vehicles. I think it was called Fix-A-Gauge.
Dave
"It is better to remain silent and be thought a fool, than to open one's mouth and remove all doubt."
Ben Franklin
1970 Chevy shortbed
2002 Harley Custom Chopper (Long sucker)
1998 K2500 5.7L 5-speed Longbed
1st two are My son's toys...they just live in my garage!
1997 GMC K1500 Suburban
1993 S-10 Blazer 4D (youngest son's daily driver)
2000 Dodge Ram 4WD Ext. Cab (5.9L)
Wife is a late year 1951
Old Dave is offline   Reply With Quote
Old 08-11-2004, 08:41 PM   #6
franko72
Franko72
franko72's Avatar
mine did the same thing, I just spliced another wire and re directed the route and it worked fine.
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach
My Home Page
Better to burn out than it is to rust
franko72 is offline   Reply With Quote
