08-11-2004, 01:04 AM | #1 |
Starter and exhaust pipe distance
With a stock setup of 2 inch pipe coming from a ramhorn exhaust manifold that is angled down. How far is the pipe supposed to be from the starter?
Thanks |
08-11-2004, 02:12 AM | #2 |
Forgot to add. How far is the exhaust pipe supposed to come down from the exhaust manifold before it straightens out and goes toward the end of the truck.
Thanks |
08-11-2004, 10:02 AM | #3 |
Ttt
08-11-2004, 04:12 PM | #4 |
Ttt
08-11-2004, 04:18 PM | #5 |
I am not sure on rams horns, I have hedman headers and mine are VERY close 3/4" and I have to have a heat shield installed and a mini starter.
Man I need another 67-72!!! |
08-11-2004, 05:47 PM | #6 |
Designated A-hole!
If it's not raining I will check and try to get a pic of mine when I get home.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
08-11-2004, 05:59 PM | #7 |
Thanks Krue, I appreciate it.
08-11-2004, 07:16 PM | #8 |
Fabricate till you "puke"
I have Hookers, & 1 tube is within 1/8 " of the starter.....doesnt cause a bit of problem here in the midwest with 95- 100 degree temps IMO, set the exhaust up as tight to the bottom of the truck as you can, fit it(within 1/2" of the crossmember).....just make sure there is enough room to drop the starter out , if you need to. if that 2 " tube is 1/2 - 3/4 " from the starter, it shouldnt cause any problems best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
08-11-2004, 08:49 PM | #9 |
Designated A-hole!
Here's what I came up with. I have ramhorn manifolds and what I assume is the stock y-pipe.
08-11-2004, 10:55 PM | #10 |
Thats about the distance I have on mine but its not a y I have duals.
Thanks Krue I apprecaite the pics. |
