08-11-2004, 04:48 PM | #1 |
Geared for Collision
Clutch Linkage
ok this driving me nuts, anyone got pics or a diagrahm of what the clutch linkage should look like on a 1970 k20 with a 4 speed tranny. previous owner did some real butcher work on the rod that runs between frame and engine and where it runs back to tranny. or does anone have this linkage for sale? needing to figure out something desperately. heres a pic of what i got for po's butcher work. the green circles are pieces i for sure need. the rest i may be able to get to work. any help or insights appreciated
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB 1970 C/K20 3/4 Ton 1996 Collectors Edition Corvette 1977 Corvette Coupe |
08-11-2004, 05:24 PM | #2 |
All those parts are wear items and www.gmpartsdirect.com can get them if you have the part numbers. Sometimes the site is not easy to navigate. www.chevyduty.com www.lmc.com www.yearone.com will all probably be able to hook you up.
I happen the have a Brand new in the bag GM bellcrank/z-bar but I think it also fits my pontiac so not for sale till I confirm it doesn't fit.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
08-11-2004, 09:26 PM | #3 |
yeah you were right lmc had it, dont know why i didnt look in their catalog. man that stuff is expensive. got stuff to ordered cost 108.00 for whats pictured above.
08-12-2004, 10:17 AM | #4 | |
08-13-2004, 03:44 PM | #5 |
well i got the parts already and thats not gonna work. for one the linkage rubs on the headers and for two the parts lmc sold me dont fit as illustrated in pic. the rod doesnt even come close to reaching transmission , would have to be almost twice as long. less im missing something thats not in their book? i bought everything they had for clutch linkage. also it came with this spring like a foot long i have no idea what its for as mine never had it. on top of all this i just stood up and banged my head on the master cylinder and took big chunk out of my head and if it dont stop bleeding soon may have to get stitches. i just feel like taking a big sledge hammer and pounding truck till nothing left, you know? guess ill never get this thing running. im having a bad day by the way if you cant tell. any ideas? i spent the last of my money on this linkage so guess im screwed now.
update -just got off the phone with lmc, now they tell me rod is for a 2 wheel drive and they dont sell one for 4 wheel drive. when i ordered told them it was 4 wheel drive go figure.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB 1970 C/K20 3/4 Ton 1996 Collectors Edition Corvette 1977 Corvette Coupe Last edited by Budweis; 08-13-2004 at 04:01 PM. |
08-13-2004, 04:09 PM | #6 |
tryed all those links you posted grim reaper no deal they say. only for 2 wheel drive at lmc and chevy duty and gm dealer said was discontinued 4 years ago.
ok guess im gonna get out the welder and make previous owners rigging a little better and go with. got calmed down a bit now and head stopped bleeding. just found out its friday the 13th, lol no wonder having so many probs today.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB 1970 C/K20 3/4 Ton 1996 Collectors Edition Corvette 1977 Corvette Coupe Last edited by Budweis; 08-13-2004 at 04:44 PM. |
08-13-2004, 07:43 PM | #7 |
I may have the entire setup, I'm using a NV4500 and a hydraulic clutch now. I'll see if I can find all the parts.
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" |
08-13-2004, 10:49 PM | #8 |
thanks i got it worked out now tho. i put a sleeve in the end piece and re-welded it up and cleaned it up a little and added new hardware and seems alot better now. the bracket on arm that rubbed on header i bent a little to clear which cracked weld on it then i re-welded it. looks like it should work, waiting for some of the painted parts to dry gonna put it on tomorrow. still trying to figure out where this foot long spring goes. does a spring go between frame mount and clutch? if anyone has a pic of their setup would help alot as mine was pretty rigged.
08-14-2004, 10:36 AM | #9 |
user # 2756
I'll take some pics after the storm.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
08-14-2004, 11:55 AM | #10 |
Sorry no pic, but the spring should go between the frame and the clutch fork
Real Trucks are Built not Bought Building: 1981 GM SB LowRider 1985 GM K3500 3+3 1981 GM K2500 SSB 1980 GM K2500 X-BC Hydro 1979 GM K3500 3+3 1976 GM K5 Blazer 1970 Custom 10 http://bc4x4.com/ |
08-14-2004, 12:33 PM | #11 |
yeah i figured it goes between there just dont see any way to attach it as spring is straight on end as pic below shows. its so stiff would be hard to curl end but i guess i could, so not sure how you attach straight end. checked part #s and supposedly its proper spring.
08-14-2004, 01:08 PM | #12 |
After market spring? One spring fits all? bend to fit application. The spring will be stiff. I believe the spring end mounts on the frame side, through a hole near the shock mount.
Real Trucks are Built not Bought Building: 1981 GM SB LowRider 1985 GM K3500 3+3 1981 GM K2500 SSB 1980 GM K2500 X-BC Hydro 1979 GM K3500 3+3 1976 GM K5 Blazer 1970 Custom 10 http://bc4x4.com/ Last edited by Truckstuff; 08-14-2004 at 01:11 PM. |
